Why does internal resistance occur?
Internal resistance in batteries occurs due to the voltage drop when large currents flow from an electromotive force (EMF) source, which can be attributed to the chemical processes within the battery and the physical components that resist current flow. This resistance varies between rechargeable and non-rechargeable batteries, influenced by their design and materials. EMF, equivalent to voltage, represents the energy provided per unit charge, similar to gravitational potential in a gravitational field. As electrons move through an electric field, they lose electric potential, analogous to masses losing gravitational potential when falling. Understanding these concepts is crucial for analyzing battery performance and efficiency.
khizman
I know its because the electrons stop the current but that's about all i Know!
Any ideas
also does internal resistance vary from rechargable and non rechargable batteries?
thanks :D
Internal resistance is a model to account for the drop in voltage when large currents flow from an EMF element. This non-idealness of real voltage sources can be thought of in many ways. May be it is just the chemical process is unable to sustain constant voltage over a large current range. If it is an active EMF device, there is going to always be an output resistance which will become its internal resistance. Or you can imagine that inside a battery, there are circuits, metals, etc which can be a cause for some resistance. But as these 'resistors' are inside the battery so there is no way you can remove them.
Different devices will have different internal resistances depending on their design.
ok, also EMF is the amount of energy given per unit of charge (coulomb)
what does it do to the electrons though?:shy:
EMF is the same thing as voltage, also known as electric potential. To better understand, let us compare it to the gravitational potential.
The gravitational field works on masses. A mass falling through a gravitational field will lose gravitational potential. The electric field works on charges. A charge (electron) falling through a electric field will lose electric potential (voltage or EMF).
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 24 ·
