Why does pressure decrease when fluid flows through a constriction?
  • Context: Undergrad
  • Thread starter Thread starter Sundog
    Venturi
6 replies · 4K views
Sundog
I know that the Venturi effect creates an area of higher fluid velocity with a lower pressure. However I'm having a hard time wrapping my brain around this. I would think that if a fluid passes through a contricted area, pressure would increase. Can someone explain?
Have you searched for the term Venturi Effect? What have you learned so far?
Bottom line explanation is that, if the fluid ends up going faster then it must have had a pressure difference to accelerate it. This reasoning is based on the steady state condition, after the system has settled down - just like the 'how does a resistor know what current to let through?' type questions. What happens during the transition in all these situations is much harder to appreciate. Sort out one thing at a time.
Basically I know that velocity increases and pressure decreases in order for the fluid to pass through the Venturi. But...my mind goes the opposite way haha. I'll have to let your explanation sink in :smile:
Same for everybody to start with, I think.
What's missing here is something has to maintain the pressure at the "entry" and "exit" points of a flow. Generally, depending on the source of the pressure, an unrestricted flow will have less pressure than a restricted flow, but the higher pressure related to a restricted flow occurs prior to the restriction, and it's only within the constriction that the velocity increases and the pressure decreases. Once beyond the constricted section, the velocity decreases and the pressure increases, but there needs to be something to maintain the pressure beyond the restriction, and in order to have a steady non accelerating mass flow within a pipe of constant diameter except for the restriction, the pressure before and after the restriction needs to be the same, and something needs to maintain that pressure.
Consider that static pressure is related to the random collisions between molecules of a fluid or gas, and between those molecules and the inner walls of a pipe. Assume that the total mechanical energy is constant, which is an assumption required for Bernoulli's equation. If there is a net velocity of the flow, then some component of the mechanical energy is related to the net velocity (this would be dynamic pressure * volume). The higher the net velocity, the lower the components of velocity perpendicular to the flow, so that the "randomness" of the flow is "reduced", the flow is more "organized". The static pressure is changed when the net flow velocity is changed, if the net flow velocity increases, then the static pressure decreases and dynamic pressure increases (total pressure = static + dynamic pressure remains constant) assuming no outside work is done during the transition.
