Why does slit diffraction occur?
  • Thread starter Thread starter CrimpJiggler
    Diffraction Slit
Slit diffraction occurs due to Huygens' principle, where each point in a wave acts as a source for new waves, leading to scattering independent of the material properties of the slit. It differs from Bragg diffraction, which involves scattering by the atomic structure of a solid. The discussion highlights that slit diffraction is a fundamental wave phenomenon rather than a material-specific interaction. Additionally, when two electromagnetic waves interfere, their amplitude change is not permanent; they return to their original states once separated. Understanding these principles clarifies the nature of wave interactions and diffraction phenomena.
CrimpJiggler
Is it the same thing as Bragg diffraction, in the sense that it is caused by the photons being scattered in different directions when it hits the atoms of the solid material around the slit?
Science news on Phys.org
No, slit diffraction is independent of the properties of the material on which the slits are built (As long as the material blocks the radiation from passing right through it.). Slit diffraction happens as a consequence of scattering due to Huygens principle which states that any point in a wave can be taken as a point source for new waves.
Ah yeah I was thinking of x-rays which are scattered by electron clouds. Huygens principle, thanks.
A side question: When two electromagnetic waves interfere, is the change in amplitude permanent, meaning will they still have altered amplitudes even when they are no longer near each other?
No, after the two waves "separate", they continue as if they had never encountered each other.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
