Why does the centroid coordinate appear in surface integrals?
7 replies · 3K views
JD_PM
Find ##\iint_S ydS##, where ##s## is the part of the cone ##z = \sqrt{2(x^2 + y^2)}## that lies below the plane ##z = 1 + y##
[/B]
I have already posted this question on MSE: https://math.stackexchange.com/ques...e/3155634?noredirect=1#comment6498746_3155634
My issue is with ##\iint_S ydS =\sqrt{3} \int_A ydxdy=\sqrt{3}\, \bar{y}|A|##. Concretely, I do not get why ##\bar{y}## shows up.
My issue is that I still do not understand how to deal with the argument of the surface integral. Let's say we had for instance ##\iint_S xydS## or ##\iint_S y^2dS##. I wouldn't know how to proceed. I know it is somehow related to the centroid of the figure (in this case an elliptical cylinder).
Robert Z provided a short explanation but I do not get it...
May you please provide an explanation?
Thanks
I think I get what is confusing you. Let's say you have an ellipse for which you know the centroid (center). Say the center is at ##(c,d)## and the major and minor axes are ##a## and ##b## and you know the formula for the area of such an ellipse is ##\pi a b##. Now let's say you have an integral that you want to evaluate something like ##\iint_A y~ dA## over the elliptical area. That is going to be a bit of work, but you can save yourself the work because you know the formula for the ##y## centroid of area of a region is$$
\bar y = \frac {\iint_A y~dA}{\iint_A 1~dA}$$So instead of working your integral out just note you can solve this equation for ##\iint_A y~ dA## getting$$
\iint_A y~ dA = \bar y \cdot \text{Area of ellipse} = d \pi a b$$since ##d## is the ##y## coordinate of the center of the ellipse.
Oh so if we were to have:
$$\iint_A yx~ dA$$
Could I do:
$$\iint_A yx~ dA = \bar y \bar x \cdot \text{Area of ellipse} = de \pi a b$$
I have just seen ##x##, ##y## and ##z## applied individually but not multiplying (that is why I am asking).
$$\iint_A yx~ dA$$
Could I do:
You can probably answer that for yourself. You would be using a formula like this:$$
\bar x \bar y = \frac {\iint_A xy~dA}{\iint_A 1~dA}$$You know the formulas for ##\bar x## and ##\bar y##. Put them in there and see if you think it is true.
OK so I think you may agree that:
$$\iint_A xy~ dA = \bar x \bar y \cdot \text{Area of ellipse} = cd \pi a b$$
You are just guessing. Until you show me what happens when you do what I suggested in the last line of post #4 you won't be able to do anything but guess. And you won't learn anything.
We know that:
$$\bar x = \frac {\iint_A x~dA}{\iint_A 1~dA}$$$$\bar y = \frac {\iint_A y~dA}{\iint_A 1~dA}$$
Then:
$$(\frac {\iint_A x~dA}{\iint_A 1~dA})(\frac {\iint_A y~dA}{\iint_A 1~dA}) = \bar x \bar y = \frac {\iint_A xy~dA}{\iint_A 1~dA}$$
So this equality doesn't hold. Then the following is incorrect:
Then we have no alternative but work the integral out.
JD_PM said:
We know that:
Then:
Good, that's a step in the right direction. So it looks like the equality doesn't hold. You do understand that "looks like" isn't a mathematical argument though, right? So what you should do now to really settle the matter for yourself is actually prove that it doesn't hold by working out a simple example and showing you get different numbers. Then you will KNOW it doesn't hold.
