Why does the movement of electrons create fields?
  • Thread starter spagettot
32 replies · 5K views · last reply
spagettot said:
no no no i think i understand now, all the fields in the electrons act a bit like a crowed of people individuals have interact with each other and the environment but they're combined interaction make the whole field right ?
It may be a good idea to approach Electromagnetism in the same way as the Science started off. It dealt with Charges and Fields and assumed they are continuous. Forget about electrons in this context; Maxwell's Equations (well before electrons were discovered) deliver the right answers until you get way down the line into relativity. The effect of Fields on moving Charges is straightforward to calculate. But there is one little awkwardness that can arise to do with interactions, namely the question: which is charge and which produces the field? Coulombs law uses the idea of point charges and the mutual force. Does the Earth pull the Moon or does the Moon pull the Earth (same question with a different context).
Jason Hogan said:
the magnetic force can be understood as
That's a 'very healthy' way of putting it. People often want to imply 'that's the real explanation" but often many models lead to the same experimental prediction. The nice thing about the Lorentz explanation is that it seems to catch the fancy of a lot of students as it uses an unexpected link to what is often regarded as a different part of Physics. Two loose ends now tied together.
WWGD said:
Isn't an F- field just the region of space where the force F acts?
Yes, basically.
A Field (vector) is just one way of describing the variation of Potential Energy (scalar) in space. E = dV/dr in one dimension. The Force is the product of the Field and the charge (other combinations exist - like weight, field and mass)
