Why does this Bra Ket (with creation and annihilation operators) equal zero?
7 replies · 7K views · last reply
unknownuser9
1. Explain why <n|(a-a+)^3|n> must be zero
2. a and a+ (a dagger) are the raising and lowering operators (creation and annihilation operators).
3. Because it says explain, I am not sure any mathematical proof is needed. I am best answer is that because (ignoring that the bracket has been raised to the power 3) a+ increases the value of n by 1 and a decreases it by 1, the overall operation on n will be zero leaving <n|n>. Because n (bra) and n (ket) must be different for a transition intensity to be observed, the overlap integral of <n|n> equals zero thus the entire thing is zero. Am i on the right tracks?
Im pretty stuck so any help would be useful. Thanks in advance!
You've got it backwards. The states [tex]|n\rangle[/tex] should be an orthonormal basis, so
[tex]\langle n'|n\rangle = \delta_{nn'}[/tex]
and [tex]\langle n|n\rangle = 1[/tex].
The fact that the power, 3, is odd is important. Think about the kind of terms that appear in the expansion.
Firstly, thank you for the reply.
Secondly, does that mean, being orthonormal, <n'|n> = 0?
The kind of terms? All i can think is that they are operators and operate on n to raise or lower is as such:
a|n> = n^1/2|n-1>
a+|n> = (n+1)^1/2|n+1>
The expansion? By expanding the bracket, i get aaa + a+a+a - a+a+a+ - ...etc
Sorry, I'm still confused. Thanks
Orthonormal in general means the vectors in a basis for a vector space have zero inner product with each other (so they are orthogonal) and unit product with themselves (unit norm, or normalized). So in this case it's precisely the equation I wrote down.
a|n> = n^1/2|n-1>
Since you're still having problems, try to compute [tex]\langle n|a a^\dagger a^\dagger|n\rangle[/tex] explicitly. Does it suggest anything about the expectation value of the rest of the terms in the expansion?
I have solved the question you gave and got n^1/2.n+1<n|n+1>. (Sorry if this is wrong but I am trying!)
Thinking about it, after expanding and solving all the terms (aaa + a+a+a - ...), it should cancel to zero?
You need to be more careful when computing the action of the operators, since your coefficient is wrong. Each operator acts in turn, so
[tex] \langle n|a a^\dagger a^\dagger|n\rangle = \langle n|a a^\dagger (a^\dagger|n\rangle) = \sqrt{n+1} \langle n|a a^\dagger |n+1\rangle[/tex]
The next operation will bring in a factor of [tex]\sqrt{n+2}[/tex].
Assuming that you can go back and get the factors right, what can you say about the value of [tex]\langle n|n+1\rangle[/tex]?
Oh i see so when the second a+ operates, the factor becomes [tex]\sqrt{n+2}[/tex] and not [tex]\sqrt{n+1}[/tex].[tex]\sqrt{n+1}[/tex] = n+1 (it is not multiplied but instead increases the number that is added to n).
<n|n+1> would give an answer of zero therefore making the entire Dirac bra-ket and the factors zero?
This would give (after expansion of the bracket) 0 + 0 + 0 ...?
Thanks
I think the penny has just dropped! I understand why the power being odd is important now!
Thanks for your help.
