Why does water get 'hard' on impact?
Water appears soft when touched gently but becomes hard upon high-impact entry due to the rapid distribution of forces across water molecules. The resistance force experienced by an object in water increases significantly with speed, with drag force being roughly proportional to the speed cubed. For example, at an impact velocity of 20 m/s, the instantaneous force can reach 5.4 kN. The drag equation applies to both water and air, but its validity varies based on the flow conditions, with different equations used for turbulent versus laminar flow. Understanding these dynamics is crucial for assessing the dangers of high-impact water entry.
Ask1122
Hi all, have been wondering, why is it that when you put your hand in water, it's soft and there is hardly any resistance, but when you jump into it like from 100m above, you will most probably kill yourself?
Is it because there is not enough time for the forces to distribute across the water molecules at the time of impact?
How much resistance force (friction force) an object moving through a medium experiences depends upon the speed (obviously- no speed, no force!) and experimentation has shown that the resistance to motion in water is roughly proportional to the speed cubed. That is, if you go through water at twice the speed, you feel eight times the force.
It is due to drag, the resistance to a body traveling through a fluid.
F_{drag} = \frac{k_{drag}\rho v^{2}A}{2}
k_drag — drag constant (k/1)
ρ — mass density of medium (kg/m^3)
v — velocity relative to medium (m/s)
A — cross-sectional normal area (m^2)
Let's say that water has a mass density of 1000 kg/m^3, the impact velocity is 20 m/s, the normal area at impact (of two feet) is ~0.03 m^2, and the drag constant is 0.9. This results in an instantaneous force of 5.4 kN.
Thanks for the reply guys!
I suppose that drag equation are used in drag for cars as well?
Yes, that's the drag equation for cars ( k is normally written as Cd for aerodynamic drag)
The drag equation not really correct for hitting the surface of water, the equation is valid for what we call turbulent flow - when you are going fast through a fluid and the air or water is swirling past you. There is a different equation for when you are going slowly through a thicker fluid - like oil flowing through an engine
Notice that it depends on Cd (which is why makers quote it for sports cars) - how streamlined the shape is.
but also A (the front area) - which is why fast cars are small.
And V^2, so as you go twice as fast the drag increases by 4 times - this is what really limits the speed of cars.
it's called surface tension
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
