anonymous99
- 24
- 4
H
Hmm. Maybe the fact that it's hollow would change the internal stresses it develops? Not sure.anorlunda said:So why do you think a balloon does not explode or collapse?
Our bodies are soft and partially hollow. Continue thinking about the balloon, and I bet that you'll answer your own question.John781049 said:Hmm. Maybe the fact that it's hollow would change the internal stresses it develops? Not sure.
And not all that attractive to some. . . .anorlunda said:Our bodies are soft and partially hollow.
That's true, but a cube has 6 sides, not 2 and that matters here.John781049 said:If I applied 1 MPA to both ends of the cube, I would still expect the bar to get crushed despite the forces balancing because of the massive internal stresses it would develop.
John781049 said:Summary:: The usual explanation I read online is that the internal pressure of our body equals the external atmospheric pressure so the forces cancel out. But say we had a solid bar. If I applied 1 MPA to both ends of the cube, I would still expect the bar to get crushed despite the forces balancing because of the massive internal stresses it would develop. So when there's 1 bar of pressure acting on us both from the inside and outside, why doesn't the same happen?
H
. . . .and so has any other object that doesn't have a totally rigid envelope (e.g. a submarine). Our cells were formed under pressure, from water and chemicals that were also under pressure and so it's always there and there will be no 'damage'. Any gases inside or outside the envelope may be absorbed or released is there is a pressure change. Under very high pressures, the forced solution of some gases (Nitrogen, for instance) can damage the body's chemistry (Nitrogen narcosis, for instance) and when pressure is reduced, bubbles can be formed as gases come out of solution, causing damage sometimes (decompression sickness or the bends, for instance). The system remains stableZapperZ said:our cells have internal pressure
We do not have enough energy to vaporize violently. We would outgas, chill and eventually dessicate.Mister T said:We are crushed by it, and the way we feel is the way it feels to be held in place by the atmosphere. Without it we would vaporize. Violently.
That’s true (I remember a good sci-fi adventure where the crew successfully breathed vacuum during an in space transfer. Not evidence of course) but there will be / could well be gases trapped in voids which would expand and give problems. Divers, coming to the surface from deep water need to breathe out or breathe naturally constantly. Holding your breath can result in a lungful of trapped air that won’t vent. Nasty.jbriggs444 said:We do not have enough energy to vaporize violently. We would outgas, chill and eventually dessicate.
