- 1,864
- 34
If x-ray beams, which has less wavesize than light, go through walls. And radiowaves, which has higher wavesize than light, go through walls. Why don't light go through walls then?
Neohaven said:The basis for relativity was the fact that light goes at a constant speed, regardless of the frame of reference.
We have object A going at 0.5c and it sends out a beam of light. the beam of light goes at c, from the point of view of any observer, on the ship, or "stationary".
(c is the named constant for the speed of light in a vacuum.)
Jarle said:ah, ok, thought it the answer would be something like that. I just have another question about light:
I read that lights speed in vacuum is a little under 300 000 km\h.
If you throw a rock forward in 20km\h from a car that is driving in 20km\h the rock will go in 40 km\h if you observe it from the ground.
But if light is sent from the Earth forward in the direction the Earth goes. (lets say that the Earth are moving in 10 000 km\h (not that i know) ). will the light speed up 10 000 km\h then? 300 000 + 10 000 = 310 000 km\h. will the light be going in 310 000 km\h then?
Jarle said:you said that the light would go at "c" speed in the observation of every point? so you mean that a man standing still, will see it in 300 000 km\h and the man i movement of 200 000 km\h would ALSO see it in 300 000km\h?? wouldn't the moving man see the light in a speed of 100 000 km\h?
I don´t think you understood. It means that everyone will measure the speed of light to be the same value c, no matter where the light came from or whether he moves relative to the source. That´s a fact.Jarle said:The light is constant i have understood that
Jarle said:I read that lights speed in vacuum is a little under 300 000 km\h.
Jarle said:you said that the light would go at "c" speed in the observation of every point? so you mean that a man standing still, will see it in 300 000 km/s and the man i movement of 200 000 km/s would ALSO see it in 300 000km/s?? wouldn't the moving man see the light in a speed of 100 000 km/s?
Jarle said::S that is un-understandable. The light is constant i have understood that, but a man traveling at a speed of 200000 km/s in the same direction of the light, should see the light 100000 km/s faster than him.
finchie_88 said:Just to make sure, if there is an observer moving towards a "stationary" light source, then will there be blue shift? And likewise, if the observer is moving away from the source, would there be red shift? if so, how do you calculate it?
P.S. Is there something like a background medium that EM waves travel through, yet we can only see the 3D effects caused? Can this medium (if it exists) be detected?
clj4 said:The answer is "no" to the first question , resulting in a "no" to the second .Lots of people spent a lot of time and a lot of experiments on this issue.
finchie_88 said:Thank you for the link.
I'm assuming that no one is still researching this area any more then. Also, one final question about relativity: Is space-time itself a physical thing (i.e. is it really there) or is it simply a convenient way of describing what is seen? As in, was it "invented" to help explain things like the orbit of Mecury and gravitational lensing of light around the sun?
finchie_88 said:I'm assuming that no one is still researching this area any more then.
finchie_88 said:Is space-time itself a physical thing (i.e. is it really there) or is it simply a convenient way of describing what is seen?
thoms2543 said:in length contraction, is the ruler really shorten?or it is just an optically illusion?
