Why Don't Spherical Waves Interfere According to Huygens Principle?
The discussion revolves around the application of Huygens' principle to the phenomenon of interference in wavefronts, particularly in the context of monochromatic light and diffraction through slits. Participants explore why interference patterns are not observed when light is emitted directly onto a screen without passing through slits or gratings, and how this relates to the behavior of spherical waves.
  • Some participants question why spherical waves do not interfere when monochromatic light is emitted directly onto a screen without slits.
  • Others argue that Huygens' principle allows for the construction of subsequent wavefronts from point sources, suggesting that these waves do interfere.
  • It is proposed that interference patterns require two or more coherent light sources, while a single source does not interfere with itself.
  • Some participants note that in single slit diffraction, different points along the slit act as point sources, leading to interference and producing a diffraction pattern.
  • A later reply mentions that the uniform intensity observed on a screen without slits is a result of the interference of waves from secondary sources, despite not showing a traditional interference pattern.
  • Concerns are raised about the coherence of light sources, with some noting that thermal light may not produce interference due to uncorrelated phases.
  • Questions arise regarding the behavior of laser beams in relation to single slits and edge diffraction, with references to specific scenarios and links for further reading.
Participants express differing views on the nature of interference patterns and the role of Huygens' principle. There is no consensus on whether spherical waves interfere in the absence of slits, and the discussion remains unresolved regarding the conditions necessary for observing interference patterns.
Participants highlight the heuristic nature of Huygens' principle and its limitations, particularly in relation to coherence and the dimensionality of space. The discussion also touches on the complexity of diffraction theory and the need for coherent light sources to observe interference effects.
alikazemi7
Hi
according to Huygens principle every point on the wave front acts as a spherical source. so if a we emit monochromatic light on a screen without passing light from grating, we should see interference pattern but we don't. why don't these spherical waves interfere with each other? is this principle is valid when wave is passing through slits?
Science news on Phys.org
The purpose of Huygen's principle is to start from a wavefront and from that, construct the next (a little later) wavefront. The spherical wavefronts from each point source do interfere (add) with each other, and result in the next wavefront.
so according to what principles we see interference patterns when a wave pass through a slit or grating?
In order interference pattern to show up, you will need two (or more) light sources with the same wavelength so that they interfere with each other. If you have a single light source, it doesn't interfere with itself. When the wave passes through a slit or grating, (huygens principle) there is two light sources, and because the light comes from the same source, both of them has the same wavelength, so they interfere and therefore you see an interference pattern.
but in diffraction phenomenon in which we have a single slit and of course one source, the wave interfere with itself and we see interference pattern.
In a single slit, different points along the width of the slit act as point sources and emit spherical wavefronts. Again, subsequent wavefronts can be constructed using the Huygens principle. These waves do interfere on the screen and produce the interference (or diffraction) pattern.
this is my question: when monochromatic light emits on a screen without passing from a slit/slits we don't see interference patterns. why the spherical waves on the wave front don't interfere with each other in this situation?
They do interfere. What happens is exactly what happens if you start widening the slit. More spherical waves with a complete range of phase differences are interfering, giving an overall uniform illumination.
What do you mean by
Marcis Rancans said:
What do you mean by ?
So, if monochromatic light hits a screen directly, you are using Huygens principle to construct successive wavefronts. The envelope of the spherical waves from individual point sources keeps producing the next wavefront of the same shape, and when the last wavefront hits the screen, every point on the screen is hit by the same state of the wave, and therefore shows the same intensity. This is seen easiest for plane wavefronts, and you just replace one of the wavefronts with a screen.
We should note that the Huygens principle is used to construct wavefronts, and not interference (or diffraction) patterns. These patterns are explained by the Huygens-Fresnel principle, and the use of it for a single slit diffraction pattern (Fraunhoffer). This takes into account the phase differences of spherical waves emitted by different points along the width of the slit, and interfering on the screen. I doubt if this part can be described without actual calculations, which are given in any book on optics.
First of all to see interference effects through diffraction you need a coherent (or at least partially coherent) light source. If you use, e.g., thermal light, you have light waves emitted from a lot of spots which have totally uncorrelated phases, and thus the light is completely incoherent. It thus cannot interfere, and thus just the intensities add (this is however only approximately true; in principle there's also interference in such cases; see the Hanbury-Brown and Twiss effect).
Second, one should be aware that Huygens's principle is very heuristic and valid only in odd space dimensions (so it's in fact valid in the usual 3D space), but that's another story.
The full theory of diffraction is quite complicated. Have a look in a good textbook on optics, e.g., Born and Wolf or (a bit more compact) Sommerfeld Lectures vol. IV.
What if we use a laser beam whose diameter is smaller than the width of single slit. Will we see light and dark pattern on the screen when the beam only hit one edge of the slit? what if the laser beam goes through between the edges of the slit, without hitting them?
The problem is that you consider "interference pattern" only the alternation of maxima and minima.
What you see on a screen without any slit or grating it is the result of interference (or can be considered to be) of the waves produced by these secondary sources. The "pattern" is a uniform distribution of light intensity. Maybe decreasing smoothly from center to the edge.
When you put something in the path you simply cut off some of the previously interfering waves so the pattern will change from the uniform to something else.
In that case we have edge diffraction:
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/bardif.html
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/difopa.html
In that case we get no diffraction.
jtbell said:
Are the solutions derived from Huygen's principle?
The pattern shown in the first link only occur when the laser is spread eg. by lens, but when the laser beam is not spread, the pattern doesn't occur.
The formula often used to derive single slit diffraction implies that the source of interference pattern is the space in the slit, as shown in this video
which should be still applicable in the case of small diameter laser beam without hitting the edge of the slit.
additional evidence that the diffraction effect originated from the edge of the obstacle. Shine a laser beam on a single slit diffraction with vertical slit orientation. You get usual single slit diffraction pattern.
Then tilt the slit by making its top side closer to the screen. Now the pattern becomes circular, whose center located on the elongation of the slit.
Huygens wavelets are not proven to exist so far as I am aware, but are a means of obtaining the correct answer. There is an anomaly with the theory that the radiation from the Huygens Source has to be assumed to radiate only forwards with a cosine shaped lobe, and this is incompatible with a very small source. Whenever a wavefront is curtailed in any way, by cutting off the edges for instance, or by an obstruction, there is diffraction.
Have you ever heard about non-diffractive obstacle or non-diffractive slit?
  • · Replies 17 ·
  • · Replies 17 ·
