Why eletric charge in Dimensional Analysis and not eletric current?
Electric charge is considered a basic physical dimension in dimensional analysis because it represents a fundamental quantity, while electric current, defined as the flow of charge, is more complex and dependent on time. The Ampere, as an SI base unit, is influenced by relativistic effects, making charge a more stable and universal measure. The discussion also touches on the CIPM's proposal to redefine some SI base units based on fundamental constants, suggesting a shift towards more consistent and universal definitions. Many participants express that current SI definitions may require revisions to enhance clarity and coherence in scientific measurements. Overall, the preference for charge over current in dimensional analysis highlights the importance of stability and universality in physical measurements.
ksio.amaral89
2 questions,actually:
1-Why in Dymensional Analysis is eletric charge a basic physical dimension instead of eletric current(as Ampere is a SI base unit and Coulomb isn't)?
2-I've read CIPM(or International Committee for Weights and Measures in English) is proposing new definitions for some of the current 7 base units,in which the supporters want to set some of the current definitons based on fundamental constants such as Avogadro or Planck constants.For further information:
http://www.bipm.org/cc/CIPM/Allowed/98/CIPM2009_49_TIMING_THE_NEW_SI.pdf
What's your opinion?Do you consider that the current SI definitions need revisions?
As you know, current is the rate of flow of charge and therefore the unit of charge is simpler than the unit of current. Relativity has a lot to do with charge being a more convenient unit than current as charge is not affected by time dilation so the Coulomb remains the Coulomb whereas the Ampere depends on your frame of reference.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
