Why I can burn a paper with magnifying glass and sun?
  • Context: High School
  • Thread starter Thread starter Physicsissuef
    Glass Paper Sun
The discussion revolves around the phenomenon of burning paper using a magnifying glass and sunlight, exploring the underlying physical principles, including the role of electromagnetic fields, energy concentration, and chemical reactions involved in combustion.
  • Some participants propose that light is an electromagnetic wave that carries energy, which can be concentrated by a magnifying glass to raise the temperature of paper to its burning point.
  • Others argue that the magnifying glass focuses light onto a small area, increasing the localized energy and thus heating the paper sufficiently to ignite it.
  • A participant questions the interaction of electrons in the paper with the concentrated electromagnetic field, suggesting that this may lead to the release of energy in the form of heat.
  • Another participant discusses the concept of activation energy, explaining that the magnifying glass concentrates energy to a smaller area, increasing the energy-to-amount ratio necessary for combustion.
  • Some participants explore the idea of using magnets to burn paper, questioning whether it is possible and discussing the limitations of magnetic energy in this context.
  • There is mention of induction heating as a method to generate heat using magnets, though its direct application to burning paper is not established.
  • One participant explains that the magnifying glass works through refraction, bending light to create a focused image, which is relevant to the discussion of how it can concentrate energy.
Participants generally agree on the role of the magnifying glass in concentrating light to burn paper, but there is uncertainty regarding the specifics of electron interactions and the feasibility of using magnets for similar effects. Multiple competing views remain on the latter topic.
Some claims about the interaction of light, energy concentration, and combustion processes involve assumptions that are not fully explored or defined, such as the exact mechanisms of electron excitation and the role of activation energy.
Physicsissuef
Why I can burn a paper with magnifying glass and sun? Isn't it something to do with the electromagnetic field (because light is itself electromagnetic field)?
Science news on Phys.org
Yea, light is an electromagnetic wave depending on how you look at it. It also carries energy. With a magnifying glass, you are concentrating the energy entering the area of a lens into a single point. That is sufficient to raise the temperature of a single point high enough for a chemical reaction to occur.
Each ray of light contains a small amount of energy. If you have a magnifying glass that's 2" around, then without the glass in place, that light would go right through the empty ring where the glass would normally be and strike the paper. This energy is spread out over all [tex]2 \pi r^2[/tex]. Now if you put the lense in place, it will take the same [tex]2 \pi r^2[/tex] of light, and focus it on a small area the size of a point. All this concentrated light means a high localized energy, which is enough to heat up and burn the paper.
Its not so much as light is an EM wave, as it is what the lense does to the light, it focuses it.
http://www.coolschool.ca/lor/PH11/unit8/U08L04/conv1.gif
Ok, thanks. But what happens in the paper? Do the electrons react opposite to the electromagnetic field, which is concentrated in small area of the paper?
The paper part in the focal area is heated by radiation so intensively that its temperature is higher than the burning temp of paper. It burns naturally. You put a piece of paper against a hot iron bar, it burns as well.
I am asking, is it exiting the electrons, so they release the excess of energy in form of heat and burn the paper?
It that really is our question then you were confusing things by asking about magnifying glass. Yes, light is a form of electromagnetic field and so applys a force to electrons (It would also apply a force to protons but they are much heavier and more tightly bound than electrons). "Visible light", an electromagnet field in a specific range of frequencies, will excite electrons in our eyes, causing vision (of course if the field is to strong- if the light is too bright- that could be dangerous. "Infra-red" light has frequency slightly less than visual light and caries more energy. It can excite other electrons than just those in our retina and cause feelings of warmth and heat. If it is strong enough, it can cause the electrons to move much faster, developing enough "friction" to cause fire.
basically, paper undergoes 'combustion'. Which means that the paper combines with the oxygen in air. This is accompanied by a release in energy in the form of both light and heat, which is what we call 'fire'.
Now, each chemical reaction has something called the 'activation energy'. This energy is required so that the transition states of the molecules participating in the reaction are modified in such a way that the reaction occurs. Transition state refers to the arrangement of electrons in the 'orbits' [not orbitals]. Molecules in the ground state generally do not react, and hence the electrons need to be excited and led to their 'excited state', where they do react. The energy required to bring about this change is termed as 'activation energy', which is what you provide when u bring that magnifying lens in front of the paper.
Now, you may ask why the magnifying lens is required? Activation energy is measured in a unit of dimensions Energy/Amount. What you do is, you reduce the 'Amount' to which a given energy is supplied. In other words, you 'concentrate' the energy to a very small area. Smaller area means, that there is less of paper there, which corresponds to lesser amount. Thus, you get a high Energy/Amount ratio.. which if is greater than the activation energy, causes the paper to burn.
The fire you see is energy given out by the system. Combustion is an exothermic process. I am not sure how the light energy is given out, but the heat energy is given out due to the formation of new bonds [bonds means attraction; attraction releases energy]. The newly formed compounds are much stabler, and hence the energy released by the new bonds while formation is larger than the energy consumed by the old bonds while breaking, thereby resulting in a net energy release.
for light energy, I'm making a wild guess that the molecules after the reaction are stable and electrons are at lower energy levels. Since the electrons jump down energy levels during the reaction, they emit photons, which is the light component of the fire. As i said, I'm not sure about how light is formed.. this was just a guess.
EDIT:
HallsofIvy posted b4 me .. while i was writing this.. and i thought that maybe i got ur question wrong.. I have given my answer on the chemistry part of it.
Ok, thanks to all for the help.
Will I get the same effect if I get magnet, it have again energy?
depends on how you use the magnet? Just moving the magnet over paper or something like that will do nothing [other than whatever friction will cause], because the paper is magnetically neutral i.e. it is non-magnetic. I can't really think of a way of how you can use it to directly radiate energy to the paper [u can like setup a small generator and stuff from the magnet.. but that'd be plain silly..]
also.. please be clear about your questions. It is incomprehensible in many instances..
So, is it possible to burn paper with magnet, somehow?
You have to find a way to turn magnetic force of the magnet into thermal energy somehow.
It is called the "kindling point". Next time aim (focus) the magnifing glass on the palm of your hand while trying to incinerate the unfortunate bug.
Yah you know what? We try not to encourage dangerous experiments around here. :rolleyes:
If you pass that magenet through a coil of wires you can generate heat through induction. Some induction systems are hot enough to melt minerals.
Yes. For example, if you build an electric motor for class, make sure you make the axle from something that is more heat resistant than a ballpoint pen. Trust me on this one.
But what happens with the atoms and molecules in the magnifying glass? Why we receive zoomed picture?
It's a process called refraction. Glass, and other materials with a certain index of refraction will bend light. The light is slowed and bends. The curvature adds to this.
Do you know what happens with the atoms and molecules?
Absolutely nothing. The light passes right through them. More accurately, the bonds between the atoms do not absorb any of the passing photons that have frequenices in the visible light range. Thus, the photons continue straight on their merry path. They only change course at the interface between air and glass (and vice versa).
I don't think the OP's question of what goes on molecular scale was really answered. Concentrating the light means much higher intensity, therefore you have many many photons hitting small amount of material. How exactly, on a molecular scale does that translate into increased kinetic energy? (heat)?
I'm guessing the electrons in atoms that make up the paper respond to the EM pulse that is a photon, and gain kinetic energy through this interaction... Not exactly sure how it happens though
That's why I see zoomed picture? Because of the concentration of energy? By molecules and atoms a thought, what is the structure of the magnifying glass?
No. We've got to separate out two questions here, just for clarity.
1] How does a magnifying glass burn things
2] How does a magnifing glass enlarge images
it's the same phenomenon but trying to combine the two in one answer will get confusing.
The magnifying glass enlarges things by bending the light rays from object to observer.
Light rays emanating from an object - say, a tiny dot of a flea - extend out in all directions. These rays diverge.
A magnifying glass placed close to the flea will intersect an angle of these diverging rays (let's say the angle is 20 degrees) and refract (bend) them so that all those rays are now converging and entering your eye.
Now think about what you'll actually see: you'll see an image of a flea that fills a 20 degree angle of your vision. That's got to be one big flea!
As for how the magnifing glass does its thing:
The internal structure of the magnifying glass has no effect on the light rays. The only thing that has an effect is the boundary between air and glass, and between glass and air. The only two factors that affect the light rays are: 1] the difference in optical density between the two media and 2] the angle of incidence of the rays to the boundary.
It is exactly what happens when you look into a pool or out of a pool and see a bent image. You can experiment with this easily by filling a drinking glass with water and sticking a straw in it. Watch how the boundary between air and water bends the light rays. The internal nature of the two media (glass or air or water) has no effect.
wiki: 'magnification', 'refraction', 'angle of incidence', 'optical density'
Like http://laser.physics.sunysb.edu/~jennifer/pictures/refraction.gif"
Yep.
IR light has less energy then visible light. Photon energy is a direct function of the frequency of light; lower frequency means lower energy. Visible light has enough energy to participate in chemical reactions in the retinas of our eyes, and we use that to see the photons.
DaveC426913 said:
Yep.
Ok, I understand now for magnification. Now, why pure glass does not concentrate energy like magnifying glass?
I'm assuming that by 'pure glass' you mean a slab/sheet of glass because it's not the material, but the shape of the material that decides it's characteristics as a lens.
A glass slab/sheet doesn't behave as a converging or a diverging lens. What such lenses do is, they either 'spread the incoming' rays from a particular point [ex. concave lens] or 'concentrate the rays' to a particular point [ex. convex lens]. It displaces the incoming rays of light by a measure. Like, if the ray enters one side at say.. 12 cm from the left edge, it would come out from like.. 15 cm from the left edge [just as an example]. So, the displacement of this ray is 3 cms. This is known as 'lateral displacement' and all incoming rays will be displaced by 3 cm exactly [or approximately 3 cm for all] and hence there is no concentration at a particular point.
Mathematically, this displacement [d] is given as:
[tex] d = t \frac{\sin{(i - r)}}{\cos{(r)}} = t \sin{(i)} \left(1 - \frac{\cos(i)}{\sqrt{n^2 - (\sin(i))^2}}\right)[/tex]
where, d = lateral displacement, t = thickness of slab, i & r = angle of incidence and refraction at the first boundary of refraction, n = refractive index.
Yes, as rohanprabhu points out, "pure glass" will do the exact same thing. There is nothing special about the glass that a magnifying glass is made of. It is all about the shape.
It's not limited to glass - or even solids. Mirages are an example of the same refraction of light rays that simply pass through layers of air with different densities.
The magnification phenomenon from a mag glass is simply a particularly carefully-chosen configuration of angled air-glass interface.
If you look at your straw-in-drinking-glass through the sides, rather than from the top, you'll see a similar effect happening because of the angle of the air-water interface between you and the subject being viewed. It looks distorted though because it isn't just the right shape.
You could make a container that's in a lens shape, fill it with water, freeze the water to ice, smash the container and you'd have a perfectly good ice-water magnifying lens.
14K
  • · Replies 20 ·
