Why integrate at these points? (Electric potential of a sphere)
The discussion focuses on calculating the electric potential inside and outside a uniformly charged solid sphere. To find the potential, integration is performed from infinity to the surface of the sphere and then from the surface to a point inside the sphere. The potential at infinity is set to zero, which influences the integration limits. The electric field expressions differ for inside and outside the sphere, necessitating the division of the integration into two segments. Understanding this structure is crucial for accurately determining the potential at any point relative to the charged sphere.
tappling
Find the potential inside and outside a uniformly charged solid sphere of radius R and total charge q.
V(r) = -∫E dl
I just have a question about finding the potential inside the sphere. Why integrate from infinity to the surface of the sphere (infinity to R) and add the integral of inside the sphere (R to r, whatever radius is inside the sphere). I'm just having trouble visualizing this integration, and why the integral is structured the way it is. Thanks in advance!
This is tied to the question: Where are you choosing V = 0?
Remember, when you integrate -∫E\cdotdl between two points, you get the potential difference between those two points. So, if you want the potential at a point P, you can integrate from the point of zero potential to the point P.
Thanks for the reply!
So, if I'm interpreting this correctly, since I choose V=0 to be at infinity (the potential goes to 0 really, really far away from the charged sphere), I can integrate from infinity to point P for the potential difference. If point P is outside the sphere, I'm finding the potential difference outside the sphere. To find the potential inside the sphere, I would need to find the potential outside to radius R AND from radius R to some arbitrary r inside the sphere, because the potential outside the sphere still affects the inside potential?
To find the potential at a point inside the sphere, you need to integrate E from infinity to the point inside the sphere. Since the mathematical expression for E outside is different from the expression for E inside the sphere, you have to break up the integration into two parts.
Likes 1 person
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
