Why is air always cold when it moves at high speeds?
  • Context: High School
  • Thread starter Thread starter Raza
    Cold Wind
The discussion centers on the phenomenon of air feeling cold when moving at high speeds, primarily due to its ability to carry heat away from surfaces, such as the human body, more effectively than still air. Participants highlight that the air's temperature does not change with speed; rather, the sensation of coldness arises from forced convection and evaporative cooling effects. The principles of Newton's laws of cooling and the Bernoulli effect are also referenced to explain the relationship between air velocity and perceived temperature. Practical experiments, such as using a fan and thermometer, are suggested to demonstrate these concepts.
  • Understanding of Newton's laws of cooling
  • Basic knowledge of forced convection principles
  • Familiarity with the Bernoulli effect and its equations
  • Experience with thermodynamic temperature measurement
  • Research the principles of forced convection in fluid dynamics
  • Explore the Bernoulli equation and its applications in thermodynamics
  • Investigate the effects of evaporative cooling in different environmental conditions
  • Conduct experiments measuring temperature changes with varying air velocities
This discussion is beneficial for physicists, engineers, meteorologists, and anyone interested in thermodynamics, fluid dynamics, or the practical applications of cooling effects in various environments.
Raza
Why is it that air going at a high rate of speed always cold? For example, fans throws air at high speed and it's cold and when we, human blow air fast is always cold.
WHY?
Science news on Phys.org
The air is not actually at a different temperature just because it's moving fast. In other words, it's not really colder.
It just happens that a fast-moving stream of air is capable of carrying heat away from something (i.e. your body) faster than a slow-moving stream of air.
- Warren
- Warren
You can prove this for yourself, too. Simply get a fan, put a thermometer in front of it, and notice that the temperature does not change regardless of whether or not the fan is blowing (as long as it is not in the sun).
That's really phenomenal!
I guess that's the way windchill works.
Yep, that's wind chill.
If you walk out of a warm building into a cold evening, you'll get chilled faster if the wind is blowing than if it's not. This is because moving air can remove heat from your body faster than can still air.
If you live in a hot climate, you can experience the same thing in reverse, too. If you walk out of a cold air-conditioned building into a very hot summer day, you will warm up faster if the wind is blowing than if the air is still. You might even feel like the wind is hot, like someone's aiming a hair dryer at you. This is the opposite of "wind chill," but it is the same effect.
- Warren
You will notice also that the effect is far more pronounced if you're wet. Moving air amplifies evaporative cooling.
More importantly I think that others have fail to state is its to do with Newtons laws of cooling, forced convection moves away 'preheated' air allowing for a faster expenditure of heat from an object ( say the body) than a sample of air with a temperature excess closer to zero (the temp of the object w.r.t. the temp of environment), it is exponentially proportional
As Funker impled, heat up the thermoter a bit first, and it will cool off faster with the fan on than with the fan off.
As a motorcycle rider, it has to get pretty hot before the wind fails to cool you off significantly. I don't recall it ever being so hot that moving was hotter than not moving (must be sweating / wind cooling effect).
I agree the main "wind chill" effect is because of increased convenction cooling, but you need to be careful interpreting experiments like "putting a thermometer in the flow to measure the temperature".
There is a similar temperature effect to the Bernoulli effect on pressure:
T = t + v^2/2Cp
T = the stagnation (total) temperature of the gas
t = the static temperature
v = velocity
Cp = specific heat.
In that sense, increasing velocity (by a fan) can reduce the static temperature. What you measure with "a thermometer" depends on the local flow pattern round the thermometer. The velocity at the stagnation point on the upstream side of the thermometer is zero. And the velocity on the surface of the thermometer is zero everywhere, if you believe that classical boundary layer theory is exact.
  • · Replies 16 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 42 ·
12K
