Why is boiling water bubbling?
  • Context: Undergrad
  • Thread starter Thread starter rogerk8
    Boiling Water
41 replies · 7K views
First, I feel that have to correct my stupid self.
Consider two hollow glass tubes of say 1cm diameter (even though it doesn't matter) and 1m of length.
Both are sealed air-tight at one end while integrating a pressure sensor.
The first tube is then filled with water.
The second tube is "empty" (i.e air of normal pressure resides inside).
Putting these tubes vertically gives
[tex]P_{water}=\rho gh\propto 1000*10*1[Pa][/tex]
and
[tex]P_{air}=\rho gh\propto 0.001*10*1[Pa][/tex]
So the pressure differs about a million between water and air.
Noteworthy is that a 1m "column" of water means a tenth of normal air pressure.
That is, pressure while diving increases by one atm at each ten meters.
Roger
sophiecentaur said:
My "catastrophe" was more to do with what can happen to a heating element that is designed to heat water, when it suddenly finds itself in an insulating gas and gets much hotter than the designer expected. I wouldn't expect the pressure necessarily to rise particularly high. I would expect the small amount of gas around the heater to expand proportionally to the absolute temperature and the pressure would depend more on the pressure in the cabin (?) if the change were not to quick. (you wouldn't expect to be boiling water in a pressure vessel, would you?) That temperature would depend upon (be limited by) other forms of heat loss. I guess it could be quite high
But what if I would?
I'm hopeless with pressure so just let me use the existing formulas (while not actually teaching me anything):
[tex]P=n_{mol}RT=nkT[/tex]
This is the ideal gas law (igs) without the Van der Wall equation of state (eos).
Yet it is a gas (and not a liquid?) law.
So what happens if we where about to increase the pressure of the vessel?
There is no vapour yet so can we really use igs?
If we can, higher pressure should just mean that temperature should have to be higher.
But this is by simply inspecting igs.
It tells me absolutelly nothing about what's really going on!
Roger
PS
You may also look at igs and say that, well if pressure in the vessel rises, temperature of the fluid rises. But this has to be nonsense.
Reading about pressure in Wikipedia gave me these very interesting facts:
1) Pressure is a scalar (which means it has no direction).
2) Since a system under pressure has potential to perform work on its surroundings, pressure is a measure of potential energy stored per unit volume.
3) Gauge Pressure is relative to normal air pressure (atmospheric pressure).
4) In a static gas, the gas as a whole does not appear to move. The individual molecules of the gas, however, are in constant random motion.
5) Considering a bucket with a hole in it, the speed of liquid out of the hole is [PLAIN]https://upload.wikimedia.org/math/0/8/3/0835a4bbe607438986f2a8705e3dab96.png, where h is the depth below the free surface.
6) Interestingly, this is the same speed the water (or anything else) would have if freely falling the same vertical distance h.
Point 2 gives J/m^3 as unit but is not totally revealed because what makes the pressure?
What is the mechanism?
It sounds good but what is "potential energy stored per unit volume" really?
Roger
rogerk8 said:
It is also interesting to hear that the vapour itself is actually insulating the element thermally from the liquid. How come?
.. . . and many others of your questions.
It seems to me that probably you need some more basic Physics if you are to go further. one can't run before walking.
There are many sources of info on the web but they will not all suit your particular level. I found this one which may help you. Try to read a lot of it before coming up with questions.
In yet another attempt in saving my face I need to revise my pressure calculations above.
In the air case I am just measureing ambient (which I prefere to call it) pressure.
Nothing else.
This came clear to me while thinking a widening of the tube diameter and its impact on pressure.
I could just widening it as much I want while considering the pressure outside of the border/tube.
The pressure outside of the tube will of course be the same as inside of the tube.
And it doesn't matter how high the tube is.
You will still get the ambient pressure (at the bottom to be extremely thorough).
In other words, Gauge Pressure is zero in this case.
When it comes to water I am however measureing a total pressure (ambient + gauge).
While water pressure is so much higher than ambient pressure I may however say that I am measureing the water (gauge) pressure only.
Roger
PS
Now that I know this I may actually calculate the height of the atmosphere.
[tex]p=\rho gh\propto 100kPa[/tex]
Using the approximate density of air (which however probably varies with height) from above we get
[tex]h=\frac{p}{\rho g}\propto\frac{10^5}{10^{-3}*10}=10^7m=10^4km[/tex]
Hmm, I don't think the atmosphere is 10000km :D
So something is wrong here.
Still I think that within a couple of thousand meters above the surface of Earth, the density is about the same.
And I do think that the height of the atmosphere is somwhere around 100km.
Thank you very much for that link.
Please correct me if I'm wrong but isn't the whole purpose of a forum to ask questions?
And cut some corners?
I have studied more than you might believe and I'm tired of theory!
I want to understand.
To understand my own way.
Not by reading a lot of formulas about everything which often actually teaches you nothing.
Nothing that makes you really understand, anyway.
So I'm using this nice forum to "blog" about my thinking.
Hope you don't mind :wink:
Roger
PS
Please do not take my questions too seriously. Sometimes I ask a question just to get it on the table while being only lightly insecure about the answer.
In any case, I refere to my signature.
sophiecentaur, I wish to add a link in my signature would you mind helping me?
I can't seem to find out how to do that.
Roger
I take back my former statement, your link seems to lack equations almost totally so it is just educational.
Thanks!
Roger
As far as I am concern ed, "tired of theory" is the equivalent of "tired of Physics".
If, as you say, you want short cuts then you run a massive risk of getting such a limited view of the subject that you will get totally the wrong picture.
If you don't like equations then you are also limiting your potential understanding. Maths (and I have made this point so so many times on PF) is the language and If you don't want to use it, you just can't get it. Someone else on PF likened it to the process of trying to study French poetry without learning the French language.
Sorry. I have no idea. You could try one of the computer based sections of PF.
Interesting.
You misunderstood me completelly.
I love equations, but reading litterature often gives you equations while you at the same time do not fully understand the basics behind them.
What I'm saying is that you need to have a kind of abstract understanding of the subject before you are being served equations.
Otherwise the equations just look nice.
Like the ideal gas law which I still do not understand.
But I'm beginnig to grasp the concept of (gas) pressure in the terms of J/m^3 with the thankful aid of Wikipedia who told me that a system under pressure has the potential to do work on its surroundings which means that pressure is a measure of potential energy stored in a unit volume.
I can relate to this but actually I do not understand this at all!
Roger
Today at gym it suddenly struck me that
[tex]P=\rho_s \frac{dv}{dt}...[N/m^2][/tex]
This while only thinking unit substitution in the familiar
[tex]F=m\frac{dv}{dt}...[N][/tex]
But this also makes me kind of begin to understand pressure which is my quest.
It tells me that gas pressure has to do with collective behaviour of a gas.
Because it has mass within a unit area (i.e surface density).
It seems like force isn't relevant within a gas and that it's counterpart is pressure.
This is obvious from the way I derived this.
But don't think I'm ready with my quest.
Far from it!
Let's view the acceleration part that is
[tex]a=\frac{dv}{dt}[/tex]
We have collective behaviour but what about this part?
How do we know it?
Imagening a particle of gas hitting the cannister wall.
If we for simplicity consider totally elastic collision.
The impulse change is then (normal angle)
[tex]\Delta p=2p[/tex]
or with regard to speed, 2v due to same mass.
So we have a maximum speed change of 2v.
Okey, let's consither this and set
[tex]dv=2v[/tex]
Now, during how long time did this speed change happen?
Because if we doesn't know that, we do not know what the pressure is.
Even though we might be able to calculate it knowing density and temperature, but that is cheating :oldbiggrin:
So what limits the rate of speed change?
Because throwing a steel ball into a steel wall will give the same speed after as before but during what time span?
Wait a minute, wouldn't the steel ball just fall to the floor right next to the wall?
I understand nothing :oldlaugh:
Roger
PS
I should have said "I'm tired of reading" and not "I'm tired of theory", sorry.
Also, I think it is important to fully understand all the variables before any equation really makes sense.
If you take a column of water and throw that at a window at a certain speed, the window will shatter at a certain length of that column.
But if you take a column of gas and throw that at a window at the same speed, the window will shatter at a certain area of that column.
The first statement is due to liquid incompressibily which makes force a matter of column length.
The second statement is due to the gas being compressible and thus force is not dependent of column length but on the integration of surface density.
How far off am I now?
Roger
