Why is the center of mass formula defined that way?
5 replies · 2K views
madah12
is there any intuition of why the center of mass formula is what it is? in high school the teacher says is is what it is and that's that or something like that but is there any logic behind it?
You can think of the center of mass as the (weighted) average location of the mass of an object.
What center of mass formula are you talking about?
If you mean
[tex]\overline{x}= \frac{\int\int\int \rho(x,y,z)xdxdydz}{\int\int\int \rho(x,y,z)dxdydz}[/tex]
[tex]\overline{y}= \frac{\int\int\int \rho(x,y,z)ydxdydz}{\int\int\int \rho(x,y,z)dxdydz}[/tex]
[tex]\overline{z}= \frac{\int\int\int \rho(x,y,z)zdxdydz}{\int\int\int \rho(x,y,z)dxdydz}[/tex]
where [itex]\rho[/itex] is the density function and M is the total mass, then, as Doc Al said, it is basically an averaging.
Imagine having n masses, m1, m2, ..., mn at distances x1, x2, ..., xn from one end of a platform. Let [itex]\overline{x}[/itex] be the distance from that end to a pivot below the platform at which the platform will balance. The torque due to the weight of each mass, around that end, is the weight times the distance: migxi. The total total torque on the board due to the weights is (m1x1+ m2x2+ ...+ mnxn)g. Of course, the pivot must be exerting an upward force equal to the total weight (m1+ m2+ ...+ mn)g and the torque due to that is [itex](m_1+ m_2+ ...+ m_n)g\overline{x}[/itex] and, in order to balance, those must be equal:
[tex](m_1x_1+ m_2x_2+ ...+ m_nx_n)g= (m_1+ m_2+...+ m_n)g\overline{x}[/tex]
the "g" on each side cancels so that
[tex]\overline{x}= \frac{m_1x_1+ m_2x_2+...+ m_nx_n}{m_1+ m_2+ ...+ m_n}[/tex]
Taking the limit as the number of masses increases and the size of each goes to 0 converts those Riemann sums into integrals:
[tex]\overline{x}= \frac{\int \rho(x)x dx}{\int \rho(x) dx}[/tex]
To convert from one to two or three dimensions, use double or triple integrals in the obvious way.
[/QUOTE]
Why is it that we know that the center of mass WILL represent the system's motion as it is one particle?
That follows from the definition of center of mass and Newton's 2nd law:
[tex]R_{cm} \equiv \frac {\Sigma{m_i r_i}}{M}[/tex]
Taking the derivative of both sides:
[tex]M a_{cm} = \Sigma{m_i a_i} = F_{total}[/tex]
ah I see it all makes sense now thanks.
