Why is the Electric Field outside this wire not zero?
bryanso
Not a homework. Just want to understand a (should be simple) example.
Why is E not zero?
Not a homework. Just self-studying electromagnetism.
I am stuck at understanding the very beginning of the solution steps in this example:
The E as given in the solution is the field away from a long straight line with charge Lambda. That's clearly not the current configuration.
E should be zero by Gauss law, shouldn't it? ... Net charge is 0.
David Griffiths Electrodynamics 4th Edition, p. 368
Diagram of a coaxial cable of length l with inner conductor radius a and outer conductor radius b, showing + charges inside, - charges on the outer conductor, opposite currents I, a battery V at the left end and resistor R at the right.
Printed solution showing the fields E = (1/(2π ε0)) (λ/s) s-hat and B = (μ0/(2π)) (I/s) phi-hat, the Poynting vector S = (λI/(4π² ε0 s²)) z-hat, and the power and momentum integrals ending in p = (IVl/c²) z-hat.
Ask yourself: The field where?
Outside is 0 from Gauss Law.
Inside conductor is 0 (after equilibrium).
So there are two fields, one on the outer surface and one on the inside contacting surface?
Am I in the right direction?
The fields are only at the surface?? Please be a little more complete in your description. Electric field lines start on a positive charge and end on a negative charge.
What about E field between a and b? By Gauss' law?
Thank you all. Got it. I knew I missed something very simple. I got misled by the general rule of thumb that there is no E inside a conductor. But this is not a homogenous conductor here. I can proceed now.
Thanks
Thanks
Right. There can be no E field inside a conductor.
In fact, unless it's a perfect NON-conductor there can be no E field in the steady-state.
UNLESS there is current flow, in which case you have E = ρι where ρ is resistivity and ι is current density.
(Vector equation.)
