Why is the ideal diode node voltage 1V, not 5V?
2 replies · 4K views · last reply
francisg3
Hello,
I have been given a homework problem about ideal diodes. The diagram is below. I need to find V and I. I have the solution (4 mA and 1V) however I am unsure as to why it is so.
I would have set 5V at the node where the resistor and 3V diode meet therefore setting all the diodes to be reversed-bias. This is obviously wrong as the voltage at that node needs to be 1V to satisy the V and I answers.
Thank you.
  • Circuit schematic: a 5V source feeds a 1K resistor R1 down to a node V, which connects to three ideal diodes D1, D2 and D3 whose anodes are driven by 3V, 2V and 1V sources; current I flows down through R1.
Yes, one of the diodes will conduct before the others and then they never get enough voltage to conduct.
It may help to consider what would happen if you gradually increased the supplied voltage from zero to 5 volts. What would happen to the current in the diodes?
