- 30,559
- 7,534
There we have it: from the horse's mouth.jim hardy said:reactive "power" isn't power at all
This has been a great, if rather inefficient way for me to get into this stuff.
jim hardy said:reactive "power" isn't power at all it's just Volt-Amps-Reactive and is wattless.
sophiecentaur said:I still must say, it strikes me as really strange that a diagram is drawn which involves a Mean Power and a Maximum instantaneous VI value
sophiecentaur said:Reactive Power gives a general idea about the various stresses that poor PF subjects the supply equipment to. I find it interesting that such a simple formula gives such an aparently useful parameter for Engineers to work with.
"Reactive power" does no work because it only shuttles energy back and forth between load and source.http://hyperphysics.phy-astr.gsu.edu/hbase/pow.html#pw said:The standard unit for power is the watt (abbreviated W) which is a joule per second.
ibidThis calculation is only for cases where the force is in the direction of the velocity, and there are many cases where that is not so. Then for instantaneous power, you just multiply the product of force and velocity by the cosine of the angle between them to get the power. In the more general cases where everything varies, one often calculates the work first and then divides by the time to get the average power.
vintageplayer said:Why not define reactive power as the amplitude of the second component in the above equation instead? Q = (VI/2). Wouldn't this make more sense because it would tell you how much the power is fluctuating around the actual supplied real power?
sophiecentaur said:No. Not me. Reactive power does represent a 'demand' on the system - otherwise no one would be bothered by it.
Now that's a strange comment. You yourself have made the point that Reactive Power doesn't come from the supply. The light bulb, itself is merely supplied with a Voltage and it 'chooses' how much current to take. If the tubne itself is purely resistive then the power that it consumes is V.I and that's what the power station needs to provide it with. The 'demand' that results from reactive elements in the load is not an Energy Demand; it just represents an overhead that's involved in extra current or volts associated with the generator (+ all the rest of the supplystuff).
I still must say, it strikes me as really strange that a diagram is drawn which involves a Mean Power and a Maximum instantaneous VI value. The coal that's shovelled into the boiler is somehow treated as the same as the extra spec needed for the components. Little wonder that 'they' tell you just to use the formula and 'get over it', without encouraging too much through about what it all actually represents.
If it is a Power Meter then it will only measure the in phase components of V and I. If your appliances happen to be very reactive, it will not be aware but still tell you the Energy dissipated per second.
jim hardy said:Power is a flow of energy from a source to a load.
Power is measured by work over time.
So the quotient work/time for reactive power averages to zero
The work done by "Reactive power" is zero. So it's not power at all. It's wattless. It requires no torque from a prime mover.
ibid
Isn't this reasoning circular? Reactive volt-amps are by definition VARS?jim hardy said:and VARS do tell you exactly howmuch reactive power ismany reactive volt-amps are circulating,
I know it's S. If S is capable of quantifying the circulating volt-amps on top of your average power, what is the utility of defining an additional quantity, Q and calling it the reactive power?jim hardy said:"Q = (VI/2)" ?
That's "S" per your first post.
Sure it works fine, but couldn't P and S do everything we need? What is the real reason for working with Q?jim hardy said:Because VIsinθ works just fine
I'm afraid that's not a valid argument. I could ask you what are the units for Work and Torque and a dimensional argument would tell us they are the same. They are not - and the difference is very much along the lines of the difference between W and 'Reactive Power'.vintageplayer said:What SI fundamental units does reactive power have? What SI fundamental units does average power have?
If "inside the device" was all that counted, the PF of any appliance would have no effect on the system. But the effect of PF of multiple appliances on the system is additive.Wee-Lamm said:my reference is inside my device
That could be real reason.jim hardy said:and we use RMS not peak or instantaneous values because that's what our meters indicate
No, S is NOT capable of thatvintageplayer said:I know it's S. If S is capable of quantifying the circulating volt-amps on top of your average power, what is the utility of defining an additional quantity, Q and calling it the reactive power?
sophiecentaur said:If "inside the device" was all that counted, the PF of any appliance would have no effect on the system. But the effect of PF of multiple appliances on the system is additive.
You seem to be rather preoccupied with finding a good model for 'what's really going on. I am being more pragmatic and looking at the overall effect (cost) of PF. It seems to me that PF is only of concern to the supplier, as long as out Energy Meters just measure Energy and charge us for Watts only. The actual effect of a particular PF and a particular Load will vary from place to place because the supply equipment is very much a part of the (£$) equation. If the load demand on an isolated power station were to be reduced (say all the factories in a town closed down) then the PF of the remaining houses and equipment would be pretty well irellevant.
vintageplayer said:Reactive power is defined as (VI/2).sinφ. This is the amplitude of the second component in the equation:
p(t) = v(t).i(t) = (VI/2)cosφ[1 + cos(2wt)] + (VI/2).sinφ.sin(2wt)
But the above equation can also be written as:
(VI/2)cosφ + (VI/2).cos(2wt -φ)Why not define reactive power as the amplitude of the second component in the above equation instead?
vintageplayer said:Having thought about this some more, defining reactive power in the first way is best because:
- Both Q and P are conservative at every node, whereas VI/2 isn't conservative. This allows a conservation of power approach to circuit analysis (much like a conservation of energy approach in physics).
- It ensures reactive power is not consumed by resistive loads. Reactive power is only consumed by reactive components. Even though you have sloshing of power across a purely resistive load, you might not necessarily want to call this a "reactive power".
- When φ is negative the reactive power is negative. This allows you to think of capacitors as supplying reactive power, and inductors as consuming reactive power.
- Q can be expressed as the imaginary component of VI*.
Wee-Lamm said:Q is not imaginary,
Sylvanus P. Thompson, Calculus Made Easy
Considering how many fools can calculate, it is surprising that other fools think it is difficult...
jim hardy said:good for you
we call it imaginary because it's current that is shifted 90 degrees wrt voltage
Operator j shifts a sinewave 90 degrees and is called i for imaginary because that's equivalent to √-1, and multiplying a sine by j twice makes it negative implying j is √-1 .
But j must be imaginary because everybody knows negative numbers don't have square roots !
So we call the in phase and out of phase components real and imaginary ... and name the axes on our phasor diagram real and imaginary.
There had to be abundant lab humor back in late 1800's when this stuff was being first worked out from lab experiments. . Here's how Sylvanus P Thompson began his calculus book
Maybe some wag in late 1800's figured out that those out-of-phase volt-amps make no heat so he called them "imaginary watts" ?
We don't get many political jokes (or historical ones) on PF. A double whammy.Wee-Lamm said:Or a Whig. :D
