Why light can't penetrate the prism with 45 degree angle
The discussion centers on why light cannot penetrate a prism with a 45-degree apex angle, primarily due to total internal reflection. Factors such as the incident angle of light, the direction of the incoming ray, and the refractive indices of the prism material versus air are critical to understanding this phenomenon. The conversation emphasizes the need for precise parameters to provide a definitive answer, as the question posed is too general. Total internal reflection occurs when light reflects back into the prism rather than refracting out, influenced by the density difference between the materials involved.
  • Understanding of Snell's Law and its application in optics
  • Knowledge of refractive indices and their significance in light behavior
  • Familiarity with the concept of total internal reflection
  • Basic principles of light reflection and refraction
  • Research the mathematical derivation of Snell's Law and its implications for light behavior at boundaries
  • Explore the concept of critical angle and its relationship to total internal reflection
  • Investigate the properties of different materials and their refractive indices
  • Study the phenomenon of evanescent waves and their role in optics
Students and professionals in physics, optical engineers, and anyone interested in the principles of light behavior in prisms and other optical devices.
Gazi
why light can't penetrate the prism with 45 degree angle?
Science news on Phys.org
You have to specify other details, otherwise the question becomes invalid because there are many situations in which a light can pass through a 45 degree prism.
Let say, light comes with wide angle like 60 degree of normal of surface and reflect with same angle. there is a formula about that in the web page. why it can't penetrate the prism with wide angle? difference of density between prism and air is a factor, is there another reason for it
That still does not add that much to give a unique solution to the original question. Other details that should be given are the incident angle, the direction of the incoming ray (i.e. from above or below the normal line), and prism material.
it's not a unique question in fact. it's a general question about the situation of light can't penetrate prism and reflect back. one reason is difference of density...
The way you phrase your question makes it as if no matter what other parameters are, so long as the prism apex angle is 45 degree, any incoming light cannot come out of the prism in the other side. I can have a situation with prism apex angle other than 45 degree but the light cannot penetrate the prism.
Density of the material? You mean the refractive indices? Then it should also have been stated in the beginning as a condition, along with other parameters which makes the question unambiguous.
It sure can "penetrate". Look at this case:
You may have in mind something but definitely did not describe it with enough detail.
Yep, it sure is. It is, as others have pointed out, SUCH a general question that it does not have an answer, or looked at differently, it has lots of answers. That's why everyone is pressing you to ask a more specific question that perhaps DOES have an answer.
Light can penetrate with 0 degree of normal of surface and it is reflected with 45 degree of normal of surface. as it seems in illustration. Density of glass is more than air. I don't ask a specific question about that. my point what is the reason of reflection of light depends on angle of it
In fact, what is called total internal reflection is a phenomenon where some light refracts, not being, then, exactly " total" this reflection.
There appears an evanescent wave at the other side of the prism, which is a patern of intensity that falls exponentially with the distance from the walls of the prism.
Nevertheless, I see that there is space for doubts with respect to the physics of this special case in the chapter of "refraction".
Best wishes,
DaTario
Snell's Law?
"Reflection" is not a physical quantity, so there is no mathematical relations which can associated to it. Nevertheless there are two quantities which may be related to the phenomena of light reflection: reflection coefficient and the angle of reflection. The dependency of both of these quantities on the incident angle can be derived through the Maxwell equations at the boundary of the two media.
  • · Replies 207 ·
13K
12K
