Why magnetic field deflects a charged particle.?
A charged particle experiences deflection in a magnetic field due to the principles of special relativity applied to electrostatic fields. Unlike electric fields, which have distinct positive and negative plates, magnetic fields operate through the interaction of moving charges and magnetic forces. The discussion references a thought experiment involving parallel lines of charge to illustrate this concept. This equivalence highlights the fundamental differences in how electric and magnetic fields influence charged particles. Understanding these principles is crucial for grasping the behavior of charged particles in various fields.
Aladin
Hello.
Sir My question is that:Why magnetic field deflects a charge particle or a charged particle experiences a force in a magnetic field?Ok
In electric field between two parallel plates a +ve charge particle deflects towards -ve plate when it is thrown perpandicularly.
But in magnetic field there is no any -ve or +ve plate then what thing in magnetic field deflects this charge?
thanks
fundamentally, the magnetic effect is the consequence of applying the effects of special relativity to the electrostatic field. there's a thought experiment, using two infinite, straight, and parallel lines of charge, that shows this equivalence, at least in this special case (so it's not a proof of the general case). instead of repeating myself, i have a post somewhere else that explains that special case to take a look at.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
