Undergrad Why Does Quantum Mechanics Require Complex Numbers?
Quantum mechanics employs complex numbers not merely as a mathematical artifact but as a fundamental aspect of its framework, particularly in describing probability interference. The Aharonov-Bohm effect illustrates that the complex phase of the wave function has significant implications beyond mere calculation. While any complex number can be represented by two real numbers, this transformation complicates the notation without offering deeper insights. The discussion raises the philosophical question of whether the underlying nature of reality is inherently "complex." Ultimately, the nature of quantum mechanics and its reliance on complex numbers remains a profound topic in physics.
MichPod
Is the fact that QM uses complex numbers should be considered as a math artefact (as it is the case when complex numbers are used for alternate current circuit analysis), or, alternatively, it has some deep and important relation to the nature (or at least to the nature of the quantum theory)? If the later is true, could you please clarify or bring some links discussing the topic?
Complex numbers are needed in order to correctly describe the interference of probabilities. However, the complex phase of the wave function is not merely a mathematical artifact, as is shown by the Aharonov-Bohm effect.
Whatever can be described by one complex number can be described, as well, by two real numbers. Some denotations may look more cumbersome in such a real notation, that's all.
Well, a rational number may be described as a pair of integer numbers as well, but we believe (most of us) that the rational numbers give probably more adequate description of the reality than such a pair.
And... even if we pass to two real numbers instead of one complex number, we still will emulate the complex arithmetic with them. The question is - why? Is the nature in its underneath somehow "complex"?
MichPod said:
The question is - why? Is the nature in its underneath is somehow "complex"?
Physics doesn't answer "why" questions.
I suggest you read the link I gave, and other threads on PF on the subject (look for "Similar Discussions" below).
Thread closed.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
  • · Replies 36 ·
  • · Replies 33 ·
