Why supercapacitor energy density is so high?
The discussion centers on the energy density of supercapacitors, particularly in comparison to traditional batteries. Participants explore the underlying mechanisms of charge storage in activated carbon and the role of electrolytes, while questioning the validity of claims regarding energy density and the nature of materials used in supercapacitors.
  • One participant notes that while batteries can have a high number of free electrons per atom, activated carbon likely has significantly fewer free carriers, raising questions about how supercapacitors can achieve high energy densities.
  • Another participant suggests that the structure of capacitors differs from solid blocks of carbon, implying that surface interactions and electric fields play a crucial role.
  • It is mentioned that in capacitors, charge flow occurs in the metal plates rather than in the dielectric, which may complicate direct comparisons between batteries and supercapacitors.
  • Several participants express uncertainty about the carrier concentration in activated carbon, with one questioning whether it could exceed one free electron per thousand atoms.
  • One participant clarifies that activated carbon acts as an insulator in supercapacitors, while the electrolyte conducts current, emphasizing the importance of surface area in enhancing capacitance.
  • Another participant discusses the concept of the electrical double layer in supercapacitors, noting that it allows for effective charge separation without a conventional dielectric, which contributes to high capacitance.
  • There is a suggestion that various designs and materials may exist for supercapacitors, which could affect their performance and energy density.
  • One participant expresses skepticism about the claims of supercapacitor energy density, hinting at potential exaggeration or fraud in the marketing of these devices.
Participants express a range of views on the mechanisms of charge storage in supercapacitors and the validity of energy density claims. There is no consensus on the exact nature of the materials or the comparison to batteries, indicating ongoing debate and uncertainty.
Participants highlight limitations in understanding the carrier concentration in activated carbon and the specific configurations of supercapacitors. The discussion also reflects varying interpretations of the roles of materials and structures in energy storage.
Stanley514
In battery we have (in ideal) case one electron per atom or three elecrons (in case of aluminum) which flow from anode to cathode.In activaded carbon there should be immensely smaller amount of free electrons than in metals.I do not have exact date for carbon, but for example in Germanium it is 2.1 x 10^12/cm-3 compared to 8.4 x 10^22/cm-3 for copper.Ten orders of magnitude smaller.I guess number of free carriers in carbon should be even lower than in Germanium.Therefore ultracap made of activated carbon shoud provide us 10 billions times smaller amount of electrons flowing from anode to cathode than battery with anode made of copper.Yet it is claimed that best ultracapacitors could rival lead-acid batteries in energ densiy.How is it possible?
Why indeed! Anyone got a retroactive QM explanation maybe?? / bump
Capacitors are not made out of solid blocks of carbon. On surfaces (and with strong electric fields present), things are different.
Edit: Made the main point clearer
Assuming Stanley imagined a solid lump of carbon, that answer's fine with me! I have a hard time imagining capacitors as solid chunks of stuff! :/
In a Capacitor, charges do not flow in the dielectric; instead, the molecules polarise. The flow of charge is surely in the metal of the plates towards and away from the surfaces of the plates. I don't think the two storage systems are comparable, which could account for the apparent paradox.
So what is carrier concentration per cm -3 in activated carbon? Could you provide any exact data?But I have doubts that even with activation carbon would have more free electrons than 1 per thousand of atoms.More likely even much less.And how many positive ions per carbon atoms have supercap to counterbalance the charge?
In supercaps activated carbon serves as plates and "the metal".
The number of free electrons is irrelevant because activated carbon is the insulator, not the conductor in a supercap. The electrolyte is what conducts the current. The way activated carbon is made gives it an immense amount of surface area for such a small volume, which greatly increases the capacitance of the device.
So by your definition; we have non conductive 'carbon insulators', separated by conductive (charge storing) electrolytes (whose charge depends indirectly, somehow, on the surface area of the non-conductive insulating carbon layer)..?
Hmm, I think I misread the description of the supercap.
EDLCs do not have a conventional dielectric[citation needed]. Rather than two separate plates separated by an intervening insulator, these capacitors use virtual plates that are in fact two layers of the same substrate[citation needed]. Their electrochemical properties, the so-called "electrical double layer", result in the effective separation of charge despite the vanishingly thin (on the order of nanometers) physical separation of the layers. The lack of need for a bulky layer of dielectric, and the porosity of the material used, permits the packing of plates with much larger surface area into a given volume, resulting in high capacitances in practical-sized packages.
In an electrical double layer, each layer by itself is quite conductive, but the physics at the interface where the layers are effectively in contact means that no significant current can flow between the layers[citation needed]. The double layer can withstand only a low voltage, which means that electric double-layer capacitors rated for higher voltages must be made of matched series-connected individual EDLCs, much like series-connected cells in higher-voltage batteries.
I was mistaken in that the carbon is used as the electrodes, not the insulator.
I would hazard a guess that there are several potential component designs for such devices utilising differing materials & configurations around similar principles.
Amongst other things, yes! I suppose it would be best to see how the hyperbole holds up before anyone tries to retroactively explain anything :P
Heard anecdotally that supercap energy density was somewhat comparable to lithium cells at present, would that be pertinent to the OP's question? Assuming we're not still talking about solid chunks of carbon?
I think there could be some fraud with those supercaps...
  • · Replies 28 ·
  • · Replies 16 ·
