sophiecentaur said:
I have a feeling that you are still hanging on to the 'little bullet' model of a photon, in your head. (...) How big would your photons be in that case? Any model you have for light and gamma must also fit in with these and even longer wavelengths. (...) interference pattern a wave phenomenon or a probability distribution
I don't hanging on the "bullet" model of the photon, this is why I mentioned the energy transfer as "teleportation", it doesn't matter. Even if it is a (delayed by c) teleportation, in correct experiments you can (and logical to) consider a path for it. I hope you can understand this, please let me know if this is not acceptable for you. The "bullet form" is an easy way to imagine that if the freq/energy is high, the effect of the photon can be limited to a small area (point-like spot on the detector screen) which is much more exact than what the wave function can describe -- exactly because the reason of the wave function is not to define exactly the annihilation place, but gives only its probability, so the "result" of the calculation of the wave fuction is obviously a wider range than when what we can determine as "path" or "ray".
If we are counting with long wavelengths (low freq/low energy) then this is the same: you can define a path for it, which will be a (more-or less) straight line, especially if we compare it to some kind of an interference pattern of it (which will be a very wide range in case of long waves, I think). We can say the same: if we "disturb" the log waves, we will get a different path. (however I have heard about several models where the phenomenon of the "bullet-like" photon is fit also for the long waves, but doesn't matter now, this is different topic)
"I can't think why you are drawing a distinction between the diffraction phenomenon due to two slits and for a single hole or slit. In neither case is there a 'direct path' through the aperture(s)."
I don't wanted to draw a distinction between these, I wanted to show that in both of the cases we can imagine the effect as the path was disturbed.
Now I'll try to explain once again why I think that it is OK, if we want to describe a 'direct path', for any cases, sorry for my bad english. I'll try to make a numbered list (steps), please let me know in which point you don't agree.
1. We can define 2 point-like areas/spots for the photon: the source and the destination. We can detect the photon in an (more or less) exact place when it is arrived to the detector screen. By the wave function we can't determine this place so exactly, because the reason of the wave function is not to give a place, but a wider range and probability levels in this range.
2. These 2 points can be connected. First of all physically: we can make it sure that the source energy arrived to the destination. Secondly: we can imagine a path, for example we can draw a straight line between this 2 points. (in the beginning this is up to our imagination)
3. We can make lots of similar experiments, and we can conclude that the energy transfer (lets say photon) behave similarly every time.
4. By putting obstacles between or near to this imagined straight line, we can aware the followings: there are obstacles/material that reflects/blocks the energy transfer (the photon). By several experiments with obstacles, we can draw a conclusion: sometimes the path can be a straight line, sometimes not. For example in case of a pipe, or a mirror...
5. If there is no disturbing obstacle, we can measure the size/width of the area, where we can detect the photons destination places. By this we can assume a width of a straight path (maybe we are wrong, but we can assume), by this we get a "more or less" straight path area.
6. Now let's take an obstacle made of a special material. We experienced earlier that if we block fully the more-or-less straight path with this obstacle, then it will fully blocks the transfer and absorbs the energy. But now we will just put this obstacle not exactly between the 2 points, but close to this more-or-less straight path. The obstacle will not even touch this imagined path.
7. Now if we measure the energy transfer we will find 2 things: 1: a very little energy portion will be absorbed by this obstace. (or: if we do the experiment photon by photon then sometimes it will block the photon before it arrives to the screen) 2: the destination place area is bigger compred to the earlier mesurement (step 5). We will call this phenomenon as "diffraction"
8. On the new destination place we will find such arriving points of individual photons, which can not be connected by a straight line from the emission point.
9. We can now conclude the followings for sure: A): If there is no disturbing obstacle, we can imagine a straight line as path for every individual photon every time. B): If there is a disturbing obstace, then there are cases when there is no straight line available (the material disturbs the path, this is ok) C): if the obstace is close enough to the imagined path that we described in A) (but not blocks it at all) it may result that some start-end points can't be connected by a straight line.
10. There are other scientifically accepted cases, when we can talk about the modified path of the photon (without "direct touch" of an obstacle/material), for example one of the proof of the relativity when the curved path of the photon was detected near to the Sun, and the modification was caused by the spacetime curvature. In this case it was exactly given why the path was not straight. Also it was important to know what was exactly the force/field/effect that caused the "disturbance".
11. It is not a stupid state if someone assumes that in case of 9.C the photon path was disturbed not by a "direct touch" of the material of the obstacle, but there is some effect near to it (in the hole) that caused the disturbance of the path.
12. The case 9.C and 10 is similar, for the first view it differs only by the size of the experiment (ok, the similarity can be only an illusion)
13. I found two cases for 9.C: 1: at the surround of the obstacle we can imagine some effect that causes the path disturbance 2: the obstacles(material) have an additional feature -- it can not only reflect/absorb the energy but also can "draw it closer" (ok, this sounds stupid :-) )
14. It is clear that 2 kinds of "force" can cause any "disturbance" for the photon itself (electric and spacetime curvature). By this if we want to imagine a path change of it and this seems to be not a "direct touch" then the cause of the change is also some kind of an (indirect) effect of these forces.
Thank you for your patience.
