DrStupid said:
Nobody was thinking about an expanding universe when the speed of light has been considered to be infinite.
A better question would be why the universe has been considered to be static.
Yeah that is true, thinking about an expanding universe may be too premature at that point.
Well, thinking again about the issue, I think I meant to say that the rates are unsynchronized, but doesn't have to be different, though it could be.
Surround a point in space with an imaginary 2d sphere. I
f every point on the surface shines inwards towards the center at different times, then there would be a continuous beam hitting the center since every moment in time corresponds to a light particle launched towards the center under two conditions. 1)Infinite universe in age and size. 2) Infinite speed of light with a very large universe.
1)the universe is infinite in age and size, assuming stars always existed, then every point on that sphere would truly map towards the center, even if light was finite in speed because just by chance out of infinite possibilities of arraignment of infinite stars.
2) But if light is infinite in speed, then I don't think an infinitely old universe is required, just one infinite in size or very large, then the same would happen. All points on that 2d sphere would converge towards the center. In fact, if the universe here is infinite in size, then since light here is also infinite in speed, then you would have infinite overlapping particles of light hitting the center of the sphere at the same time.
In modern parlance, this would reduce everything to a kugelblitz black hole, leaving the universe in a state of maximum and constant entropy, which we know is not true.
But back then, they should still suspect that points in space everywhere would burn up, since light is bright and in general, bright things have heat, fire is hot, sun is hot, molten metal shines and is hot etc, so it is not unreasonable to assume that light itself could be associated with thermal properties.
