Why we dont feel the current from Earth wire?
The Earth wire only carries current during a fault in electrical equipment, which is typically brief until the main fuse blows. The ground acts as a large conductor, dissipating any current over a vast area, making it undetectable under normal conditions. Normal wiring does not produce significant currents in the Earth wire that can be felt. However, downed power lines can create dangerous situations, and it is advised to maintain a safe distance of 30-50 meters. Understanding these principles clarifies why we don't feel current from the Earth wire under normal circumstances.
avito009
The Earth wire carries current to the ground and we walk on the ground and the ground is a good conductor of electricity. So when we walk on the ground then how come we don't feel the current from the Earth wire?
the Earth wire doesn't carry current unless there is a fault with the equipment, tool, etc
and if its working correctly the current flowing in the Earth wire should be very brief till the main fuse blows
if that doesn't answer your question, then you need to be much more clearer about the situation you are referring to
cheers
Dave
I think you are asking why we don't feel any current on the ground. The Earth is a big place, so the current is dissipated.
Earth/earth wire provides path of much less resistance
As the others said, with normal wiring there are no significant currents in the Earth to be felt.
However, if a power line is knocked down by accident and touches the ground, it can be very dangerous to approach it. Stay 30-50 meters away.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
