Will a 9V electromagnet work with a battery of a lesser voltage
A 12V electromagnet can operate with a 9V battery, but it will generate a weaker magnetic field. While the electromagnet itself may function, other components in the circuit, such as transistors, might not work properly at the lower voltage. This could lead to the entire circuit failing to perform as intended. It's important to consider the overall circuit design when using a lower voltage power supply. Therefore, while possible, using a 9V battery with a 12V electromagnet may not yield optimal results.
radaballer
Will 12v electromagnet work with a 9v battery?
Yes it will, but as you might expect, it produces a weaker magnetic field.
Likes radaballer
Well, it might work. If you have other electronics in the circuit they may not function at the lower voltage.
Likes radaballer
Yes Drak that is true, I am assuming OP meant just a simple power source supplied to an electromagnet.
If the electromaget is somewhere in a circuit which includes other components, transistors or so, they may not work with a lower power supply setup, and the circuit would not function as intended.
Likes radaballer
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
