Will two out-of phase lights cancel out?
  • Context: Undergrad
  • Thread starter Thread starter Negatron
    Lights Phase
The discussion clarifies that two out-of-phase light sources cannot cancel each other out due to their incoherent nature. Incoherent light sources, such as LEDs, do not produce interference patterns necessary for cancellation. Coherent light sources, like lasers, can create interference patterns, but even then, cancellation at all observer positions is not achievable unless they originate from the same point. The phenomenon of wave cancellation is utilized in cell phone tower designs to optimize energy transmission.
  • Understanding of coherent and incoherent light sources
  • Basic principles of wave interference
  • Knowledge of quantum mechanics, specifically photon behavior
  • Familiarity with the law of Etendue in optics
  • Research coherent light sources and their applications in optics
  • Study the principles of wave interference and patterns
  • Explore the law of Etendue and its implications in optical systems
  • Investigate the design and function of phased array antennas in telecommunications
Physicists, optical engineers, telecommunications professionals, and anyone interested in the principles of light behavior and wave interference.
Negatron
I'm sure this is a silly question. My understanding of waves would suggest that it should be possible to put two (small) light sources side by side in such a manner that no light energy reaches most observer positions, yet my understanding of electromagnetism is insufficient to confirm this possibility. I've certainly never experienced a phenomenon of something like two LEDs next to each-other canceling each-other's light.
Science news on Phys.org
Do you know what coherent light sources are?
I will soon :smile:
So am I correct to assume that this is possible but an atypical phenomenon because all natural light sources are incoherent?
No. Because two different light sources are incoherent, there cannot be an interference pattern.
Ah, alright. Thanks.
This isn't a silly question at all. It touches huge swaths of physics including thermodynamics, electromagnetics, basic conservation laws, and quantum physics.
In quantum mechanics, a photon (an indivisible unit of light) is it's own antparticle which means it should be possible to cancel out light with light. The trouble is where would the energy go?
If you spend the time to go through this you will find connections between the second law of thermodynamics and optics through the law of Etendue. This law says (in my own reformulation) that you can't take two beams of light that are side by side and make any optical system that overlays the beams, so this answer says no, you can't cancel light with light.
LEDs do emit incoherent light, which makes it difficult to observe interference patterns. However, it is not difficult to make two sources that are coherent and have a stable phase relationship with each other...an antenna makes it easy, a bit more difficult would be lasers locked to a common reference, or one laser split along two paths. In fact, a laser shining through two slits or pinholes is equivalent to this, and shows the interference pattern you'd get.
The real answer is that even if you have coherent light sources with opposed phases, the fact that the sources do not originate from the same position will keep them from canceling out at all points. You get interference patterns, just not patterns such that "no light energy reaches most observer positions". With more sources, you can confine the emitted energy to smaller, more sharply defined areas or spread it out, but you can't make it go away, the best you can do is absorb it. And there is no way to emit both from the same location...this is simply equivalent to not emitting anything.
Agreed. This sort of phenomenon is actually used in cell phone towers, for example. They set up a bunch of towers spaced equally apart in a straight line, with the proper spacing such that the waves radiating parallel to the line cancel out. This way the antennas don't waste energy transmitting in those directions, where there are typically no people. Conversely, the waves transmitted perpendicular to the line of towers, in the direction of population, reinforce each other.
  • · Replies 24 ·
