The discussion focuses on designing a 5V DC to 5V AC, 5W wireless charging circuit operating at 275kHz, which is outside the typical 85kHz Qi standard. The recommended approach involves using resonant SMPS topologies such as an LLC half-bridge or a Hartley oscillator with a high-Q LC tank to minimize harmonic distortion and EMI, especially considering FCC regulations on AM band interference from harmonics. The transmitter coil should be larger than the receiver coil and placed as close as possible (ideally under 1 cm) to maximize coupling efficiency. Bluetooth control via an ESP32 is used for power management, and pre-made coils with ferrite backing plates are preferred for consistent inductance and efficiency.
- Resonant LLC half-bridge SMPS design principles
- Hartley oscillator operation and LC tank circuit design
- Wireless power transfer coil coupling and magnetic flux management
- FCC regulations on harmonic emissions in the AM radio band
- Research Texas Instruments and Analog Devices resonant wireless power control ICs
- Study coil design optimization including coil size, turns ratio, and ferrite core usage
- Implement Bluetooth-based power control using ESP32 for transmitter activation
- Analyze harmonic filtering techniques to comply with FCC EMI standards
Embedded systems engineers, power electronics designers, and hobbyists developing custom wireless charging solutions at non-standard frequencies who require guidance on resonant circuit design, EMI compliance, and coil coupling optimization.
