Wireless Charging
16 replies · 4K views · last reply
Sterer
TL;DR
5V DC to 5V AC, 5W
I need a circuit that converts 5V DC to 5V AC and can supply 5W for a wireless charging coil. I am finding incredibly little information online
Edit: It also needs to run at 275kHz, so a standard relaxation oscillator to my knowledge would not work
Welcome to PF.
How are you physically going to place the charging coil and the target device? How close will they be?
Also, keep in mind that the 3rd harmonic of your charging frequency is in the AM radio band, which is regulated by the FCC in the US (and there are similar regulations around the world). If you cause interference with your charging device, you could be subject to some penalties.
What is the application?
Sterer said:
TL;DR: 5V DC to 5V AC, 5W
What is your use case for this charger? It may not be good for phones
It is for charging a battery connected to a custom external board. It does not need to be too efficient but should deliver some amount of power
Over what distance? Can the charging coil be placed in direct external contact with the battery case? Or better yet, can it be designed so the battery power receiver part fits inside the charging coil, kind of like some electric toothbrushes are recharged?
Black electric toothbrush standing upright in its round charging base on a counter, with a white bowl-shaped sink and a beige wall in the background.
https://www.google.com/url?sa=t&sou...cKEwjQloWF2oSTAxUAAAAAHQAAAAAQCA&opi=89978449
Nothing should be visible externally, but there is a possibility to have the charging coil inside the receiving coil. They will be over a cm apart though.
Also, keep in mind that the 3rd harmonic of your charging frequency is in the AM radio band...
As is the 2nd, 4th, and 5th. Typically the 3rd and 5th are higher in amplitude than the even harmonics. I believe I have this right. Feel free to correct me as I would put more faith in your knowledge of RF than pretty much anyone I know these days.
At any rate, this is a challenging project for a beginner. Anyone who phrases the original post in the way that it was I would have to assume is in fact a beginner.
I would look into resonant SMPS designs. My first guess is a resonant LLC half-bridge topology, but I haven't looked into this for a few decades. There is a lot of information available and probably some control ICs. Look at TI.com and Analog.com (or google) for starters.
If you're not finding info on the web, you're searching for the wrong things. It's out there, lots of it.
Agreed. I was just using the 3rd harmonic because it is usually the biggest depending on the signal generation circuit, and was an existence proof that there may be regulatory issues.
The problem is not creating a 5W 275kHz sinusoidal waveform with low harmonic content to drive a charging coil. The problem is optimizing your wireless charging setup to help you achieve your goal. If you give us so few details about your application, you are not likely to succeed. What exactly is your application and what are your design constraints?
You could drive a loop antenna, with the square wave from a microcontroller, through a MOSFET, but that would be full of harmonics.
The solution might be an inductor driven by a power amplifier, driven by a sine wave oscillator.
I would consider a Hartley oscillator, with the resonant tapped inductor as the coupling loop. That would significantly reduce the harmonics generated. Design it to stay on frequency under load, while the voltage amplitude is regulated.
https://en.wikipedia.org/wiki/Hartley_oscillator#Operation
Why?
I'm not sure what makes a relaxation oscillator "standard", but the operating frequency isn't hard to make whatever it is.
Yes, 100% agree. You'll want the inductor to be part of a high(ish) Q tank. This will help a lot with energy storage (efficiency) in the transmitter field as well as reduce EMI in the harmonics. The EMI from the drive circuit can be filtered and contained, but you don't want anything "extra" in the transmitter coil.
It's not really your circuit question, and you probably don't have much control over the specs. But the coupling efficiency is a huge issue. Anything you can do to reduce the distance or increase the size of the coils will pay off. Can you add a magnetic core to better direct the flux? I'm thinking something like a pot core with a really, really, big gap.
Finally, I assume you've studied existing designs, like Qi. Don't reinvent the wheel if you don't have to.
For efficient inductive coupling, the wireless charging transmitter coil needs to be bigger than the range between the transmitter and the receiver coil. You say the range will be greater than 1 cm, but I do not see the diameter of the receiver coil.
Can the device requiring charge, talk to the charger through Bluetooth or similar, to turn the power transmitter on when needed, and off when done?
Resonant receiver coils usually operate at 85 kHz. Is your receiver tuned to operate efficiently at 275 kHz?
I have aimed at sending a signal at around 275kHz. It has an LC tank where C is 54nF.
Receiver coil: ID - 20mm OD - 42mm
It can talk to the charger through bluetooth using an onboard esp32. Turning on and off the transmitter is possible, but the recieving end has no sensing functionality as of yet.
Receiver tuned for 275kHz, LC tank where C is 26nF.
The receiving coil is double the sending coil to double the voltage recieved, but if the sending voltage should land at ~10-12V for efficiency, this will be changed to 1:1.
The L is locked as i am buying pre-made coils for wireless charging, i read somewhere that 250kHz - 300kHz would give the best charging efficiency so that gave me the frequency of 275kHz. (They also have a ferrite backing plate)
I have looked at a lot of different designs, and feel like Qi is too hard to implement as we are space-restricted on the receiving side. You can, but the documentation is shaky at best.
The number of turns will determine the transformer voltage ratio. The transmitter and receiver coils should be of similar dimensions. For an air-core inductor, the area will also change the voltage ratio.
I have three of the same coil, i am planning on stacking the two for the receiving side. It will be less efficient and more bulky, but i think its better than manually making a coil as that could turn out more inefficient.
This is the best advice.
If you search "Wireless Charging Transmitter and Receiver Modules" you will find many modules that accomplish this task.
Can you share the part numbers for the coils you have? How much space is free for the wireless circuit on the transmitter and the receiver?
BoB
