Word problem find equations then solve
  • Thread starter Thread starter synergix
    Word problem
The discussion revolves around solving a word problem involving simple interest, where $19.36 is earned from a principal amount at a certain interest rate. The problem states that adding $66 to the principal and reducing the interest rate by 3 percentage points yields the same interest. The equations derived from the problem are P*R = 19.36 and (P + 66)(R - 0.03) = 19.36. After attempting to solve the equations, a mistake was identified in the manipulation of the quadratic formula, leading to an imaginary answer. The correct principal is found to be $176, with an interest rate of 11%.
synergix
A certain amount of money saved for 1 year at a certain annual interest rate(simple interest) yielded 19.36$ in interest. if we had added $66 to the principal and reduced the interest rate by 3 percentage point(s), the interest would have been the same, Find the principal and the rate.
(1)$19.36= PR
(2)$19.36=(P+$66)(R-0.03)
I solved (1) for P then substituted that into equation (2)and I got a complex answer so I must have incorrectly formed the equations any help?
If I solve those equations I get a real answer which seems reasonable too. You must have incorrectly manipulated them.
Can you try typing out your calculation? If you don't spot the error while typing it, we might be able to help you find it.
Ok here you go.
first I solved (1) for R
R=19.36/P
Then I put that into (2)
19.36=(P+66)((19.36/P)-0.03)
(19.36=19.36-0.03P+1277.76/P-1.98)P
19.36P-19.36P=-0.03P-1.98P+1277.76
Then I divided by -0.03
0=P^2+66P-42529
and I found my mistake... when I used the quadratic formula and multiplied -4ac I kept it negative and therefore ended up with a large negative square root and an imaginary answer D'oh
THX!
P=176 r=0.11
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
