Work done by a gas in a piston
In summary: Just be careful not to assume that a reversible process can be approximated by a sequence of irreversible processes.In summary, the conversation discusses the work done by a gas when weights are suddenly removed from a massless piston, and whether the pressure of the gas can instantaneously change to atmospheric pressure. The conclusion is that the work done can only be accurately determined if the process is reversible, and the ideal gas law does not apply for an irreversible expansion.
goggles31
34
Let's assume that weights are placed on a massless piston and below the piston is a gas. If we remove all the weights at once, the work done by the gas should be the difference between the forces exerted by the gas and the atmosphere multiplied by the change in volume. However, we know that the pressure exerted by a gas is inversely proportional to its volume and hence the work done is given by the area under a curve. Is it okay to assume that the pressure of the gas instantaneously changes to atmospheric pressure when the weights are removed, as in Figure 4.10 of the link given?
http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/node34.html
I don't think that seems very reasonable. Try solving ##PV^{\gamma}=nRT##
In an irreversible expansion, the pressure exerted by a gas on the piston is not inversely proportional to its volume. The gas pressure is not even uniform spatially within the cylinder during an irreversible expansion. Plus, the force is affected by viscous (dissipative) stresses in the gas such that the rate of change of volume also affects the force. However, the work that the gas does on the piston can be determined if we know the external force applied to the gas at the piston face (because the gas pressure matches the "external pressure" at the piston face).
For more details on this, see my two Physics Forums Insights articles: https://www.physicsforums.com/insights/understanding-entropy-2nd-law-thermodynamics/ and https://www.physicsforums.com/insights/reversible-vs-irreversible-gas-compressionexpansion-work/
Likes BiGyElLoWhAt
This equation is not valid for an irreversible expansion, or any other expansion for that matter. If the expansion is reversible, then the ideal gas law applies (exactly as it is always written).
Also, in the link, the processes are explicitly reversible.
Not for the cases where finite weights are suddenly removed from the piston.
Hmm... I see. Removing each small weight is what they're referring to as reversible. Sorry about that.
No problem. These things are always very confusing.
1. What is work done by a gas in a piston?
Work done by a gas in a piston refers to the energy expended by the gas as it expands or contracts within a piston, pushing against the walls of the container. This work is equal to the force of the gas multiplied by the distance it moves.
2. How is work done by a gas calculated?
The work done by a gas in a piston can be calculated using the equation W = F x d, where W is work, F is force, and d is distance. To calculate the work done by a gas, you must know the force exerted by the gas and the distance it moves.
3. What is the unit of measurement for work done by a gas?
The unit of measurement for work done by a gas is joules (J). This is the same unit used to measure other forms of energy, such as heat and mechanical work.
4. How does work done by a gas affect the temperature of the gas?
When work is done by a gas, its internal energy decreases, leading to a decrease in temperature. This is because the gas is expending energy to do work, rather than retaining it as internal energy.
5. Can work done by a gas be negative?
Yes, work done by a gas can be negative. This occurs when the gas is compressed, meaning it is doing work on its surroundings rather than having work done on it. In this case, the work done by the gas is equal to the negative of the work done on the gas.
  • Thermodynamics
