Work done by force acting on a spring
37 replies · 12K views
Studiot
- 5,434
- 11
Sorry if the lines of thought were disconnected.
This is back to the original setup.
Force F is applied to draw back the mass attached to the spring to s1 and
1) Held in position.
2) Then it is released (F is removed)
Do you think the mass has gained potential energy as a result in (1) and (if so) does it still possesses this energy at the moment of release of F or just after (2) ?
The system has gained spring potential energy. And that potential energy depends only on the amount the spring is stretched from its equilibrium position.Studiot said:Do you think the mass has gained potential energy as a result in (1) and (if so) does it still possesses this energy at the moment of release of F or just after (2) ?
So: Yes, the system has PE when it is held in position (1) and immediately after the force F is removed (2).
Studiot
- 5,434
- 11
As soon as the spring is stretched it exerts a pull on the mass, which will move the mass if we let go.
What is the difference between that pull and the pull on the mass due to gravity, which would draw it down if we removed the table?
Sure.Studiot said:As soon as the spring is stretched it exerts a pull on the mass, which will move the mass if we let go.
What point are you trying to make? (You're losing me.)What is the difference between that pull and the pull on the mass due to gravity, which would draw it down if we removed the table?
Studiot
- 5,434
- 11
The objective is an energy balance or accounting.
(It's not a trick 'onest guv)
I'm merely observing that we can (I think) say that the mass has potential energy due to the elastic energy stored in the spring and thereofe the pull exerted by the spring.
This is eventually transferred to the mass as kinetic energy when it oscillates and forms the energy of the oscillation ie that which is transferred back and fore between KE and PE.
I want to end up by observing that the force F does work on the mass, which in turn does work on the spring when pulled out so the net energy of the mass does not increase when it has reached a stop at the maximum s1
I prefer to say that the system (really the spring) has potential energy, not just the mass. (For the same reason I think it is misleading to talk about the gravitational PE of a mass--it's really the PE of the mass-earth system.)Studiot said:The objective is an energy balance or accounting.
The force F does work on the system. The mass essentially transmits the force to the spring, which gets spring PE as it is stretched. When the mass is allowed to oscillate, the spring and mass exchange energy.
I don't see the issue. (Or how it relates to the OP's concern.)
Studiot
- 5,434
- 11
Yes that's true enough.
Thanks for your patience.
Undergrad Where is the centripetal force acting on mass M?
- PMANNAS
- · Replies 21 ·
- Mechanics
- Replies
- 21
High School Work Done By Conservative Forces
- Heisenberg7
- · Replies 1 ·
- Mechanics
- Replies
- 1
Undergrad Work Done/Energy Transferred in One Dimensional Collision
- MattGeo
- · Replies 5 ·
- Mechanics
- Replies
- 5
Undergrad Work done "against centrifugal force"
- Swamp Thing
- · Replies 9 ·
- Mechanics
- Replies
- 9
Find the force acting on the roller in the direction of the spring
- JackLee
- · Replies 14 ·
- Mechanical Engineering
- Replies
- 14
High School Work done in lifting and lowering an object
- rudransh verma
- · Replies 34 ·
- Mechanics
- Replies
- 34
Undergrad What is the force acting on a particle during a change in temperature?
- Lucw
- · Replies 9 ·
- Mechanics
- Replies
- 9
Graduate What is the force acting on a rotating body in a non-inertial frame?
- Silviu
- · Replies 3 ·
- Mechanics
- Replies
- 3
Undergrad Force acting on a stationary object in a flowing pipe
- ykh-1992
- · Replies 20 ·
- Mechanics
- Replies
- 20
Textbook 'The Physics of Waves': Calculating Work Done by Force
- brettng
- · Replies 2 ·
- Introductory Physics Homework Help
- Replies
- 2
