Work done by gavity on an inclined plane
The work done by the weight of a 30-N box pulled up a 6.0 m inclined plane at a 37° angle is calculated using the formula W = F·D·cos(θ). The correct approach involves determining the vertical height using h = 6 sin(37), leading to a potential energy change of 180 J. The initial calculations provided by the user were incorrect due to the misunderstanding of vector addition and the distinction between force and work, which is measured in Joules, not Newtons.
  • Understanding of basic physics concepts, specifically work and energy
  • Familiarity with vector addition and trigonometric functions
  • Knowledge of the formula for gravitational potential energy (PE = mgh)
  • Ability to apply the work-energy principle in inclined plane scenarios
  • Study the work-energy theorem and its applications in physics
  • Learn about vector decomposition and how to resolve forces along an inclined plane
  • Explore gravitational potential energy calculations in various contexts
  • Practice problems involving work done on inclined planes using different angles and weights
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy on inclined planes.
fd25t6
A 30-N box is pulled 6.0 m up along a 37 °inclined plane. What is the work done by the weight (gravitational force) of the box?
Ok so attempt goes like this:
W = FDCOS(37)
So force weight parallel to the plane is 30sin37 = 18.05N
" perppendicular " 30cos37= -23.95
add them up = -5.9n
so -5.9n(6m)cos37 = -28.3 Newtons?
is this right. Thanks in advance for the help
This is wrong because you're using the inclination wrong. The work done is defined as
<br /> W=\vec{F}\cdot\Delta\vec{x}<br />
where the force is the weight, 30 Newtons. Try again using some coordinate system (axis along the plane and perpendicular to it, for example), and try again.
More, you don't ever add perpendicular magnitudes of forces, forces are vectors. You can add vectors, but adding magnitudes is meaningless.
Also, the final result is in Joules, or if you prefer 'Newtons meter'.
hi fd25t6! :smile:
fd25t6 said:
W = FDCOS(37)
correct (except shouldn't it be sin ?) :smile:
work done = force "dot" displacement
the force is the weight, 30N, so why have you done :confused:
add them up = -5.9n
and anyway, you never add the magnitudes of forces in different directions, it's simply not allowed :redface:
just apply the equation W = F·D …
what do you get? :smile:
Is it really as simple as 30sin37?
(minus)
i] work done, like most things in physics, has a formula, and you just apply the formula! :rolleyes:
ii] work done = minus potential energy, so how much is the potential energy? :smile:
Well, PE= mgh so 30(6) = -180 J
What, exactly, are you calculating? In the statement of the problem you say "What is the work done" but at the end of your first post you say "-2.83 Newtons". Newtons is a measure of force, not "work" or energy. Work is measured in Joules. A 6 meter ramp at 37 degrees goes up 6sin(37) meters (and over 6 cos(37) meters). The change in potential energy (and so work required to move the box upward) is the force needed, 30g Newtons, times the height: (6 sin(37)(30g)= 180 g sin(37) Joules.
no, because the 6 is along the slope, not vertical (and h is vertical) :wink:
(and now I'm off to bed :zzz:)
  • · Replies 33 ·
