Mentor
- 37,401
- 16,536
Actually, the energy dissipated in the resistance for a charging series RC circuit is independent of the actual value of the resistance. For a series RC circuit with initial voltage 0 across the capacitor and with a constant supply voltage v_s after t=0 we have the differential equation:truesearch said:When the connection to the battery is made a current flows to charge the capacitor. This current will produce heat energy in any resistance and electromagnetic radiation from the wires. If the resistance is small then the current will be large and the radiation could be the major means of energy loss. If the resistance is large the current will be small and resistive heating could be the major energy loss mechanism.
[tex]C \frac{dv_c}{dt}+\frac{v_c-v_s}{R}=0[/tex]
Which has the solution:
[tex]v_c=v_s(1-e^{-\frac{t}{RC}})[/tex]
So the energy dissipated in the resistor is given by:
[tex]\int_0^{\infty} i_r v_r \, dt = \int_0^{\infty} \frac{v_c-v_s}{R} (v_c-v_s) \, dt = C \frac{v_s^2}{2}[/tex]
which is not a function of R, and is also exactly equal to the "missing" energy.
As to whether or not resistance or radiation is the dominant source, if you are using circuit theory or doing circuit analysis then one of the basic assumptions/approximations that you are making is that the radiation is 0. Even making the assumption of no radiation, you can still show that energy is always conserved, so it is not necessary to invoke radiation to explain the missing energy.
