Vivee=)
- 15
So I'm trying to push an big object and it doesn't move, am I doing work on it? Or is work 0 joules?
Vivee=) said:Ok, I have another work question. What if the box is sliding down a frictionless slope. Would the equation for work be W=w*d*cos(theta), with w=weight and d=distance? Or would it be W=w*d*cos(90-theta)? I'm guessing it's one of these because since the box is moving, work cannot be zero.
Math Jeans said:If there was no gravity, the box would just sit at the top of the slope because nothing is pushing it down.
Colin1 said:What if there was no friction?
Colin1 said:Interesting
so, if
weight = mass x gravity
is gravity a constant here? If so, what varies as what now that it's been removed?
Math Jeans said:The removal of gravity was just an example in order to show that it was the active force pushing the box down.
Work on a static object is the amount of force applied to an object that does not result in any displacement or movement of the object.
The formula for calculating work on a static object is W = F * d * cosθ, where W is work, F is the applied force, d is the distance over which the force is applied, and θ is the angle between the force and the direction of motion.
Yes, work can be done on a static object. However, since there is no displacement, the work done will be zero.
Work on a static object does not result in any displacement, while work on a moving object does. This means that work on a static object will always be zero, while work on a moving object can be either positive or negative depending on the direction of the displacement.
Some examples of work on a static object include pushing against a wall, holding a heavy object without moving it, and carrying a book while standing still.
