Calculating Work for Spilling Milk from a Parametric Dish
  • Thread starter Thread starter shft600
The discussion revolves around calculating the work required to spill milk from a parametric dish defined by the equation x² + z² = e^y, filled to a height of 5 cm. The key formula for work is established as W = ∫(0 to h) F(y) dy + (T-h)(F(h)), with F(y) representing the force due to the weight of the milk. Participants express confusion about deriving the volume and area functions from the parametric equation, particularly in converting it into a radius function. The volume of milk is correctly identified as V(y) = π(e^y)², leading to further calculations for work based on varying fluid levels. The conversation highlights the need for clarity in defining force and integrating the correct parameters for accurate work calculation.
shft600
A dish, described by the equation x2+z2=ey for 0 < y < 10cm (or equal too) is filled 5cm high with milk. How much work does it take to spill all the milk on the floor? Take milk density to be 1030 Kg/m3 and gravitational acceleration to be 9.8 m/s2.
I know that the work formula is
W= int(0 to h): F(y)dy+(T-h)(F(h)), and F(y0)=(dens)(g.acc)(Volume above y0), but I am stuck at the volume part of the equation.
It should be V(y)=int(0 to y): A(y), where the area is Pi(r)2. This is where I get stuck. How do I convert the x2+z2=ey into a radius function? So far, nobody's been able to explain parametrics to me very clearly even with just x and y, but now there's a z variable and I'm just clueless.
I got y=ln(x2+z2) and x=sqrt(ey+z2) so far..
Isn't x^2+z^2=e^y a circle in the x-z plane with radius e^y?
so then is it just the integral of pi(ey)2?
In which case V(y)= Pi((1/2)(e2y)) from 0-5, and a constant Pi((1/2)(e2(5))) from 5-10cm?
Yes, the volume is integral of A(y)=pi*(e^y)^2. I'm having a some trouble following the rest the work calculation. T is 10cm, right? So isn't the formula just integral 0 to 5 (g.acc)*(density)*(T-y)*A(y)dy?
Hm.. I'm not entirely sure, I just posted the formula straight off my formula sheet. The first part is the work of moving the varying amount of fluid, and the second just moving it out through the open space in the dish. The force is constant for the (T-h) (10-5cm), but we need to take a second integral for the force of moving the volume as it changes during the emptying. Thats what I understand from my notes, at least. If it helps I just finished the question and got this, basically:
W = (integral(0-.05): 10094pi/2(e2y)) + (.1-.05)(10094pi/2)(e2(.05))
Where the bold is the force to move the milk up until its surface in the dish and the regular face is just the force to move the then-constant volume from the 5cm up to the 10cm. I could be wrong though...
Ah, I see. The first part moves all the milk up to the 5cm point and the other part lifts it out. Ok. But your formulas still look pretty garbled. Partially because you haven't defined what F(y) is supposed to be or anything. I am thoroughly confused. Work is the integral of (g.acc)*(dens)*A(y)*(distance to lift from y)*dy. Try and formulate it from that. Your notes may be a little garbled.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
