Work Required to Pull Chain onto Table (I.I.T 1985)
The work required to pull a uniform chain of length 'L' and mass 'M' onto a smooth table, where one third of its length hangs vertically, is calculated to be M*g*L/18. The force exerted by the hanging part is M*g/3, and the height to which the center of mass is raised is L/6, leading to the correct work formula: Work = ΔPE = (M/3)*g*(L/6) = M*g*L/18. This conclusion corrects the initial miscalculation of M*g*L/9.
  • Understanding of basic physics concepts, specifically potential energy (PE)
  • Knowledge of force and displacement in mechanics
  • Familiarity with the principles of uniform mass distribution
  • Basic algebra for solving equations
  • Study the concept of potential energy in physics
  • Learn about the center of mass and its significance in mechanics
  • Explore problems involving work done by forces in various contexts
  • Review uniform mass distribution and its applications in physics
Students preparing for physics examinations, educators teaching mechanics, and anyone interested in understanding work-energy principles in physics.
prateek_34gem
Uniform chain of length 'L' and mass of 'M' is lying on smooth table and one third of it's length is hanging vertically down over the edge of the table. If 'g' is acceleration due to gravity , then work required to pull the hanging part onto the table is :
A)MgL
B)MgL/3
C)MgL/9
D)Mgl/18
(I.I.T :- 1985)
mass of hanging part will be m/3. so it will be exerting mg/3 force downward.
so this amount of force is required to pull it up.when the chain will be up its displacement along table will be l/3 because now hanging part is on table.
so
F=Mg3
S=L/3
Work = F*S= Mgl/9
But it is the wrong answer.
A)MgL
B)MgL/3
C)MgL/9
D)Mgl/18
(I.I.T :- 1985)
so
F=Mg3
S=L/3
Work = F*S= Mgl/9
[tex]Work = \Delta PE =M*g*h = \frac{m}{3}*g*\frac{L}{2*3} = \frac{m*g*L}{18}[/tex]
Your weight is MG/3 as you noted but the height that you raise the center of mass is 1/2 the length, which makes it L/6, not L/3.
Thanks a ton! You all are great . The site rocks.
  • · Replies 100 ·
11K
  • · Replies 17 ·
11K
