Write the polar form of a complex number in the form of a+ib
The discussion focuses on converting the polar form of a complex number, specifically 4{cos(13π/6)+isin(13π/6)}, into its rectangular form. Participants clarify that the conversion involves recognizing the sine and cosine values for specific angles, particularly using the special right triangle associated with 30° and 60°. The key values are derived from the unit circle, where cos(π/6) equals √3/2 and sin(π/6) equals 1/2. Understanding these relationships is essential for accurately converting between radians and their corresponding sine and cosine values. Mastery of these trigonometric principles is crucial for solving similar problems without a calculator.
thatguythere
4{cos(13∏/6)+isin(13∏/6)}
= 4((√3/2)+(i/2))
= 2√3+2i
This is an example from my textbook. The part which I do not understand is how to convert the cos and sin of radians into those fractions. Any help is greatly appreciated.
= 4((√3/2)+(i/2))
= 2√3+2i
That's basic trigonometry.
Remember to set you calculator to 'radians' instead of 'degrees' if you don't know trigonometry.
I understand how to convert between radians and degrees. What I am unsure of is how to get from the radians to those fractions. When I write the exam, I am not allowed a scientific calculator either, so I definitely need to know this. Also, Sammy, while this may be basic to you, it is not something I have ever learned. So, perhaps you could simply point me in the right direction? My textbook does not demonstrate the relevant trigonometry.
A complete circle has 360° which is equivalent to 2π radians.
\displaystyle \frac{13\pi}{6}=2\pi+\frac{\pi}{6}
\displaystyle \frac{\pi}{6}\ radians is equivalent to 30 ° .
Do you know the sine and cosine of 390° ?
Finding sine and cosine of 390° or 30° is not difficult. Converting sin390°=0.5 into 1/2 is simple as well. However, when it comes to converting cos390°=0.866 into √3/2, I am at a loss.
It's not about "converting" 0.866 into ##\frac{\sqrt{3}}{2}##. Rather it's about recognising that ##\cos{\frac{\pi}{6}} = \frac{\sqrt{3}}{2}##. 0.866 is just a decimal approximation of that irrational number.
To do that, you need to "know" the special right triangle with perpendicular sides measuring ##1## and ##\sqrt{3}## and hypotenuse ##2##. You should be able to verify that Pythagoras Theorem holds for this right triangle. The angles in the triangle are (in degrees): 90, 60 and 30 and you can figure out the equivalent radian measure. You should be able to figure out which angle is 60 deg and which is 30 deg, and the sines and cosines of those special angles should become easy to compute exactly.
BTW, that special right triangle is simply half an equilateral triangle of side length 2, bisected along one of its vertical heights. The reason why one of the angles is 30 deg should now become obvious.
Draw an equilateral triangle with each side of length 2. Draw a line from one vertex to the midpoint of the other line. That line will also bisect the opposite side and the angle. Since each angle in an equilateral triangle is 60 degrees= [/itex]\pi/3[/itex] radians, you now have two right triangles with angles \pi/3 and \pi/6 radians and with one leg of length 1 and hypotenuse of length 2. From the Pythagorean theorem, it follows that the other leg has length \sqrt{3}.
From that we can say:
sin(\pi/3)= sin(60)= \frac{\sqrt{3}}{2}
sin(\pi/6)= sin(30)= \frac{1}{2}
  • · Replies 22 ·
