Undergrad Is There an Analogous Law for X-ray Diffraction Minima?
Bragg's law describes the conditions for maxima in X-ray diffraction with the equation 2d*sinθ = mλ. The discussion raises the question of whether a similar equation exists for minima, suggesting a possible formulation of 2d*sinθ = (m+1/2)λ. Unlike simple two-slit setups, diffraction gratings do not exhibit a straightforward alternating pattern of maxima and minima. In ideal infinite crystals, intensity is only present at Bragg positions, while real crystals introduce complexities due to imperfections and multiple scattering. Surface diffraction can lead to phenomena such as "anti-Bragg" positions, further complicating the understanding of diffraction patterns.
L_landau
For x-day diffraction maxima we have braggs law
2d*sinθ = mλ (maxima)
Is there an analogous law for the minima like
2d*sinθ = (m+1/2)λ (minima?)
Thanks!
Diffraction gratings don't have a simple alternating maximum/minimum pattern like the two-slit setup does.
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/gratint.html
What you see are the primary maxima which are very narrow and bright. You don't normally see the secondary maxima and the minima in between them.
For an ideal, infinite crystal, and using the kinematic theory of x-ray diffraction, there is intensity only at the Bragg positions, and nothing in between. Once you consider real (finite and imperfect) crystals and multiple scattering (dynamical theory of x-ray diffraction), things become a bit more complicated.
As an example, in surface diffraction, you get something called an "anti-Bragg" position.
https://en.wikipedia.org/wiki/X-ray_crystal_truncation_rod
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 17 ·
