Your Thoughts: speed of gravity
  • Context: Undergrad
  • Thread starter Thread starter Arctic Fox
    Gravity Speed Thoughts
The speed of gravity is widely accepted to be the same as the speed of light, as predicted by general relativity. Discussions in the forum highlight the misconception that gravity could travel significantly faster than light, with some claims suggesting speeds up to 20 billion times faster. This notion is countered by the argument that if gravity acted faster than light, celestial bodies like Earth would experience severe orbital instability due to lag in gravitational influence. Current experiments, such as LIGO and Gravity Probe B, aim to measure gravitational waves and confirm that changes in gravity propagate at light speed.
  • Understanding of general relativity principles
  • Familiarity with gravitational waves and their detection methods
  • Basic knowledge of celestial mechanics and orbital dynamics
  • Awareness of the implications of speed limits in physics
  • Research the LIGO experiment and its findings on gravitational waves
  • Study the implications of general relativity on gravitational interactions
  • Explore the concept of retardation in gravitational effects
  • Investigate the mathematical modeling of gravity in celestial mechanics
Physicists, astrophysicists, and anyone interested in the fundamental principles of gravity and its effects on celestial bodies.
Arctic Fox
I would like everyone to comment on this.
What do you think is the speed of gravity?
Some say it’s the same as the speed of light, others claim it might be 20 billion times faster than light.
What is your idea? :)
is that "20 billion times" a stated figure or was it off the top of your head
speed of gravity? what do u mean by that, i know of acceleration due to gravity, but i don't know what u mean by speed of gravity. Perhaps your talking about the interactions of gravitons between particles?? please give details about what you are talking about. :D
The argument that gravity travels faster than light (20 billion times faster by some estimates) is that if it didn't, the gravity from the Sun on the Earth for example would have an 8 minute + lag so that the Earth would spiral out of orbit very quickly since it would be acting on the Earth's position 8 minutes ago, and vice versa. Some GR expert named Cliff something supposedly calculated that by some weird coincidence, gravity traveling at the speed of light from the sun does act on the instantaneous position of the EArth.
If I remember correctly that calculation was debunked. To the best of my knowledge, the speed of gravity is the same as the speed of light.
This is the prediction of general relativity. It hasn't been demostrated by observation yet, but big new experiments like LIGO and Gravity Probe B are closing in.
I don't know about the technical stuff, but my guess is also that the speed of gravity is the same as the speed of light.
The first argument would be equivalent to saying that each time you moved, the Sun would disappear until you came to a stop and remained stationary for 8 minutes. In reality, if you move, you run into light that left the Sun even before you started moving, so you don't see any difference unless you happen to be moving incredibly fast (you'd see a shift in the frequency of the light you're running into).
Just because the distance is part of the equation for determining the force of gravity, doesn't mean that only the 'gravitrons' (or whatever) originating at that precise instant determine the gravitational attraction (the equation isn't the reality - it describes the reality). I would think any gravitational forces an object generates exist regardless of whether there is any other body there to interact with. If another body does exist and is in motion, it, too, has its own gravitational forces that are moving with it. The equation for determining the force of gravity describes the interaction occurring where the forces from the two bodies intersect each other and is independent of the speed either body is traveling - at least, unless you're traveling some very high speeds, at which point I'm not sure what kind of difference you'd perceive that would be equivalent to the frequency shift of light.
Just out of curiosity, what kind of difference do LIGO and the Gravity Probe B expect to detect?
the foce of gravity acts at the speed of light.
if the sum just suddenly disapeared with would see and feel the effects simultaneously
I have probably said this before, but if I understand general relativity correctly, the term "speed of gravity" is not exactly valid. The LIGO experiment is attempting to detect the speed of gravity waves, which are predicted to travel at lightspeed. However, this is not exactly the same thing as the "speed of gravity" it is merely the speed at which changes in gravity propagate.
I have always described with the following analogy;
Suppose we are sitting in two small boats on the surface of a lake. There is water covering all the distance between our two boats. If I began knocking my boat, I will generate waves which will travel to your boat. You could measure the speed at which those waves are going past your boat (if you were inclined to do so), but this would not give you the "speed of water", or the "speed of lake". The lake exists throughout all the space between our boats at all times. Likewise, gravity is a curvature of space that fills up a certain area and occupies that area, not a force that propagates through or travel across that area.
Good analogy.
Why would the Earth spiral out of orbit? Gravity is a field and it acts on anything surrounding it, even if there is nothing there, there is still gravity, so if the Earth moves, there is gravity acting on it from the sun at that position keeping it in orbit. The only time there would be lag is when new matter is produced, let's say instaintaniously, the effect of gravity would kick in at speed of light.
Gravity is a pretty difficult subject so I refer you to those experts on those links. The arguments revolve around the conservation of angular momentum.
An analogy would be like swinging a ball in a circle attached to a string that is as long as the distance to the sun- if the tension on the string traveled at the speed of light the ball would not travel in a regular orbit like an ellipse, especially if you started moving as well. If you think gravity is like the presence of mass curving a rubber sheet then it gets pretty complicated I guess. In your argument you seem to be suggesting that the rubber sheet stays curved even after the mass moves away? I was thinking more like as the mass rolls down the rubber sheet, the curvature-indentation on the sheet moves with it.
What you're saying kind of makes sense but the experts apparently think it's a problem- they even have a name for it- they call it retardation. They make different assumptions then you apparently when doing the calculations. The way I think of it is like you were flying an airplane in zero visibility and had to rely on a GPS mapping device to fly, but unfortunately the GPS satellite is orbiting the Sun and not the Earth so that it locates where you were 8 minutes ago- using this delayed information, you will surely crash.
I think the "8-minute" analogy was kind of unfortunate and obscures the issue. The real issue is that, if gravity propagates at the speed of light, an accelerating object of mass wouldn't be at the center of its own gravitational field, especially if the object's rate of acceleration is constantly changing (which is true for any object orbiting in an ellipse).
It's kind of difficult to visualize how two fields, both offset from their source, would interact. I think Carlip's explanation is at least plausible, but I'd tend towards believing Van Flandern's point of view (maybe at least partly because its better written).
Definitely an interesting problem.
LIGO test of speed of gravity
One possible test is if LIGO detects a core collapse supernova event, or an inspiral neutron star pair event, then analysing any differences in when neutrino bursts, light/gammas/other EM were detected should yield limits on the difference between c and the 'speed of gravity'.
The 'retardation' etc stuff is 'just' math; IF GR, THEN how do objects (e.g. solar system planets) orbit serenely as if Newtonian instantaneous action at a distance were the real thing? At first glance, there might seem to be some contradiction; deeper analysis shows all is calm and bright.
IIRC, there's a thread or two in SR&GR which goes into this at some length ...
Gravitation has not delay to start an action.
But its action forces any object to move with the speed of light at the limit
Michael
The 8-minute argument does not prove that the gravity from the Sun would get weaker any more than it proves that the light from the Sun must get constantly dimmer.
This topic is rather confusing so let me sum up what i think is the best 2 options. One will be true, one will be false, but i do not know which one is which.
The Sun is 1 AU away. Light takes 8 minutes to get to us. Earth is pulled towards where the Sun looks like it is. In reality, the Sun is 8 minutes ahead. If the Sun is "turned off" we would not notice the loss of light, or the loss of gravity pulling us, for another 8 minutes.
The Sun is 1 AU away. Light takes 8 minutes to get to us. Earth is pulled towards where the Sun looks like it will be in 8 minutes time. If the Sun is "turned off" we would notice we are no longer being pulled towards the Sun, and then 8 minutes later, it would go dark.
Personally, I think it is like electrons in a wire. Even if they move at only 3 cm per hour, the effect on the other end is "almost" instant.
what is gravity? it is a force of course! a force that causes us to be drawn to other objects... why? because we have mass? okay gravity is a force relative to mass... but what causes gravity exactly? can anyone tell me? does gravity have mass?
This is the 'option' which corresponds to the most successful theory we to date, General Relativity (GR). By 'successful' I mean 'consistent with experimental and observational results'; in this sense, GR is a complete success - there are (AFAIK) no results which are inconsistent with GR. Of course, testing continues, with Gravity Probe B, LIGO, binary pulsars, and more.
GR is the best theory of gravity that we have today. In PF there is an entire section devoted to GR (and its 'predecessor', Special Relativity). In the Physics Napster - a sticky at the top of this section - there are many links to excellent material. Included is a copyright-free pdf-version of Firk's Essential Physics 1, which includes material on gravitation.
i think gravity is a force just like an electric field which have it's own area or a region where it's effective and it is constant it neither have speed nor acceleration.But it has a power to attract things with the same pull which we say 9.8 m/s^2.
what u guys think of my post
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 51 ·
  • · Replies 55 ·
  • · Replies 47 ·
  • · Replies 17 ·
