Yukawa potential energy function
The discussion centers on deriving the radial force function from the Yukawa potential energy function, U(r) = -(r/r0)U0 exp(-r/r0). Participants consider two methods for differentiation: normal differentiation and partial differentiation, noting that since the function depends solely on r, both approaches yield the same result. There is some debate about whether spherical coordinates are necessary for the derivation, but it is concluded that only the radial axis is relevant in this context. The gradient can be expressed simply as ∂f/∂r in the radial direction. Overall, the focus remains on confirming the correct approach to deriving the radial force from the Yukawa potential.
astenroo
This is not yet an attempt at solving a problem. I just need confirmation on that I'm on the right track. So, I am supposed to derive an expression for the radial force function from the given Yukawa-function.
U(r) = -(r/r0)U0 exp-(-r/r0)
I'm thinking about two possibilities here. First: Derivation of said function with respect to r (normal differential). Second: Partial differentiation to solve for the gradient (although I think this is not necessary since r is a fixed value, and no coordinates are given in the context of the problem)
RoyalCat said:
\vec F = -\nabla U
http://en.wikipedia.org/wiki/Del_in_cylindrical_and_spherical_coordinates
In this case the normal derivative is the same as the partial derivative.
Ah true, since this function only has one variable which is r. What I am a bit concerned about is that if the system for spherical coordinates should be used in this derivation... Or they aren't needed since the radial force is dependant only on r (in this given situation)?
It doesn't matter, you have only one axis specified in the problem, and that's the radial axis. The way to take the gradient with respect to the radial axis is \frac{\partial f}{\partial r}\hat r
It doesn't matter what the other two axes are.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
