Converting Potential Energy to Kinetic: Analyzing Resistant Forces
The discussion focuses on the conversion of potential energy (GPE) to kinetic energy (KE) using the equation mgh = 1/2 mv^2, where the mass cancels out if weight remains constant. The main challenge highlighted is calculating resistant forces such as air resistance and friction in the wire and pulley system. Participants seek guidance on how to incorporate these resistant forces into their energy balance calculations. It is noted that while the ideal scenario assumes no losses, using a well-designed pulley system can minimize friction and wind resistance. Understanding these factors is crucial for accurately determining the final speed at the bottom of the system.
daddylange
the way i see it is this is a simple potential to to kinetic balance.
mgh = 1/2 mv^2
the m's cancel assuming the weight isn't changing.
so here's the hard part.
calculating the resistant forces.
air resistance and friction in the wire/pulley
so can anyone get me started on how to calculate those energies and put it into my first balance?
GPE = maximum KE at bottom.
So, mgh at top = 0.5mv2 at the bottom. So you can work out the final speed.
Of course, that assumes no losses. But if you have a good bearing on the harness pulley the friction losses would be incredibly small from that and wind resistance.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
