An angle at each point in spacetime and A_μ?
The discussion explores the relationship between a field represented by an angle function θ(X,t) and the electromagnetic vector potential A_μ(X,t) of a moving point charge. It proposes specific identifications between θ and the components of A_μ, questioning if A_μ can be viewed as a massless field constrained to circular motion in a hidden space. There is uncertainty expressed regarding the validity of this identification and the conceptualization of A_μ. The conversation reflects a mix of curiosity and confusion about the underlying physics. Overall, the thread seeks clarification on these theoretical connections.
Spinnor
Suppose we have a field that is represented at each point in space by an angle that is a function of time, θ(X,t).
Can we make the following identification with the electromagnetic vector potential A_μ(X,t) of a moving point charge with velocity v_x, v_y, and v_z?
θ(X,t) = A_0(X,t),
v_xθ(X,t) = A_x(X,t),
v_yθ(X,t) = A_y(X,t),
v_zθ(X,t) = A_z(X,t)?
Can we think of A_μ as a massless field with each point X of the field constrained to move on a circle (circle in some hidden space)?
Thanks for any help!
I think this works,
"θ(X,t) = A_0(X,t),
v_zθ(X,t) = A_z(X,t)?"
I think something is wrong with this,
"Can we think of A_μ as a massless field with each point X of the field constrained to move on a circle (circle in some hidden space)?"
I'm confused, maybe my brain needs food?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
