Pigtail Antenna Cable: Can It Be Substituted With Coaxial?
  • Thread starter Thread starter david90
    Antenna Cable
Pigtail cables can be substituted with coaxial cables, but the choice depends on the specific application, particularly in RF scenarios. Pigtail is a general term for a short length of cable, often coaxial, typically with a nominal impedance of 50 ohms. Using a coaxial cable with the wrong impedance can reduce signal range, so careful selection based on application requirements is essential. Factors like attenuation and connector type, such as N-type for lower loss, should also be considered. Ultimately, understanding the specifications of coaxial cables can lead to better performance in wireless applications.
david90
Can pigtail cable be substitute with coaxial cable?
Not sure what application you have in mind. Are you feeding an antenna? to an rf transmitter or reciever? :rolleyes:
In my experience a pigtail cable, is a more of a descriptive term for a "short length" of almost any kind of cable and not necessaily coaxial.
Coaxial cable comes in many specifications depending on your application, things like nominal impedance, type of dielectric material, center wire may be solid or stranded, attenuation - dB signal loss, which is dependent on frequency of signal you may be using, etc.
here is an example of a few coaxial cable specifications:
http://www.rfcafe.com/references/electrical/coax_chart.htm
WiFi application
Pigtail is a skinny cable that connects an antenna to wireless PCI card.
david90 said:
WiFi application
Okay, the pigtail as I mentioned above, describes a short length of wire, which can be of any type..
Your application is definitely RF, so I would investigate using one of the coaxial cables. Do a little web search for that cable spec. You may actually find a better cable (less lossy) to use, than that which come with those cards :approve:
david90 said:
WiFi application
“Pigtail” is a term I’ve often used and often heard but it has no technical significance.
What you are describing is likely to be a short coaxial conductor with a nominal impedance of 50ohms.
Using a cable of different impedance will lessen the range.
It generally is a descriptive term, referring to a short length of cabling.
(no doubt coming from idea that a pig's tail coils and is fairly short)
Choice of 50 \Omega characteristic impedance is a reasonable starting point. However that impedance is not useful for all RF applications, so careful choice should be made in each case. Another useful parameter to consider is velocity factor.
Though the application in the following URL, is for CCTV (closed circuit television), here is an excellent primer for learning about coaxial cable parameters. http://www.pfm.howard.edu/infosys/choosing_correct_cable.pdf
Also try to choose connectors that are less lossy, such as N-type. The PCI cards vary as to which connector is needed for that end of the cable, so be sure to find out what end-connector your card uses.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
