New Reply
Volume exapnsion question
Share Thread
Jan6-13, 03:04 AM   #1
Let's say you have two bodies which are made of the same material and have the same external dimensions and appearance, but one is solid and the other is hollow. You increase their temperature, now is the overall volume expansion the same or different?
What do you think?
PhysOrg.com physics news on PhysOrg.com
>> Cheap, color, holographic video: Better holographic video displays
>> First entanglement between light and optical atomic coherence
>> EUROnu project recommends building Neutrino Factory
Jan6-13, 04:24 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi failexam!
tell us what you think, and then we'll comment!
Jan8-13, 11:26 AM   #3
The two bodies are made of the same material, so they must have the coefficients of volume expansion. Also, they have the same external dimensions.
But, one body is solid and the other is hollow. So, the solid body has greater volume than the hollow body.
Volume expansion depends on the coefficient of volume expansion, initial volume and external dimensions, so the solid body will expand more than the hollow body.
What do you think?
Jan8-13, 12:09 PM   #4
Recognitions:
Quote by failexam View Post
yes , in the same sense that a large solid body will expand more than a small solid body …
but does that necessarily mean that a solid body will expand to a bigger diameter than the originally-same-diameter body?
what do you think happens to the hole?
what happens in the easy case of a hollow cube whose hole is one-third the diameter of the whole cube (so the hollow cube is 8 cubes joined together)?
Jan10-13, 07:39 AM   #5
(as an aside, wouldn't that have to be 26 cubes? Nine on "top", nine on "bottom", and 8 between them? Basically it should be the number of cubes visible on the exterior of a Rubiks cube)
Anyway, my feeling is that the hollow and solid objects should expand the same amount--at least in appearances, from the outside.
New Reply
Similar discussions for: Volume exapnsion question
Thread Forum Replies
question on finding the volume of vapor and the volume of liquid Introductory Physics Homework 9
Partial Fraction Exapnsion General Math 1
Gas/Volume Question Introductory Physics Homework 4
Volume Question Calculus 8
volume question General Physics 7
