| New Reply |
Basics question of Inductor to powering high voltage lamp |
Share Thread | Thread Tools |
| Jan27-13, 05:08 PM | #1 |
I was trying to study the inductor role in Flyback converters and all, they seem to rely on the principle that the inductor is first energized while the switch is closed and then, it acts as a voltage source itself when the switch is opened.
All that is good, but I am confused with the POLARITY. http://www.wisc-online.com/objects/V...spx?ID=ACE5803 The simulations here seem to show all the current directions from negative to positive. Are they talking about the flow of electrons? Either ways, I don't see when the inductor gets 65volts across it to power the neon lamp. This is what I understood: First the inductor has a voltage of 10 when the switch is closed with A, then it goes reducing to zero. After the switch is closed with B, the voltage is formed across the inductor to power the neon-lamp. But all the currents shown are negative to positive? Can someone clear me on this? I am aware of the equations V = L(di/dt). So when the constant current becomes zero, voltage is there across the inductor, right? But the polarity? |
| Jan27-13, 05:37 PM | #2 |
Assume a positive supply voltage, a series L, a switch and a load connected to ground.
When you (try to) break the circuit, the voltage across the inductor will change from a small forward voltage (due to the finite resistance of the winding) to a high reverse voltage. This high, inverse voltage will be such as to maintain the current that is flowing out of the inductor into the circuit it feeds. It will provide a (positive) voltage at the switch terminal that is much higher than the original value. If a high voltage neon has been connected between L and ground, the voltage will then be enough to strike the neon. The more current the load takes, the higher the voltage when the switch breaks the circuit - which you said when referring to Ldi/dt |
| Jan28-13, 11:43 PM | #3 |
When exactly does the inductor in the link develop a voltage large enough to power a 65V neon lamp, from a 10 V source?
In the page of the time constant, it has 10 V just when the switch is closed. Then it goes reducing till zero as time passes. After that the next page has these two situations (shown in the attachment). It seems to shift its polarity once the connection is made. Even after that it seems to be showing current going from negative to positive! So which is the correct polarity of voltage at the inductor, and what about the current direction? |
| Jan29-13, 04:17 AM | #4 |
Your circuit is not the one I was discussing. 'My' switch and neon are the other side of the inductor, so my wording was not appropriate.
In your circuit, in order to maintain the same current through the resistor, when the switch is opened, the volts at the 'top' of the inductor will, as you show, go negative with a large amplitude. Could your confusion about the direction of the current be to do with the fact that the inductor is an energy source (like a battery) whilst the voltage spike is being formed. For current to flow out of it, through the resistor, the potential that end must be maintained and this is achieved by virtue of the emf, generated in the inductor. When the battery is connected, the negative end of the battery is connected to ground. Whilst the inductor is functioning, the ground connection is replaced by the neon , which will only strike when there is 65V across it. Point B will be 65V negative for this to happen. (total volts on inductor will be 75V - note that on my circuit, you only need 55V across the inductor as there is already 10V from the supply) You also mention the timing of all this. There will be finite capacitance in the circuit (mostly the self capacitance of the coil) and this will introduce a time constant which will cause a finite time for the voltage reversal. If the neon were replaced with a capacitor, you would have a series of oscillations as the capacitor discharges back through the inductor - and so on - until the energy is dissipated in the load resistor. |
| Jan29-13, 06:03 AM | #5 |
Recognitions:
Let's simplify things even more, using just a battery and the inductor. You connect the battery across the inductor, and current flows, small at first but increasing with time. You then decide to disconnect the battery. Instant removal of the battery would cause the current to instantly fall to zero. But that means di/dt would be infinite, so an infinite voltage would appear across the inductor terminals. An infinite (or, at least, very high) voltage here would jump across the gap of air between the inductor terminals and the battery you are valiantly trying to drag off the inductor, this voltage revealing itself as a blue spark. And if you do the experiment, that's exactly what you'll see. The faster you try to remove the battery from the inductor, the bigger the spark that results. The spark represents current flow, meaning the current you tried to interrupt and cause to drop to zero is actually not instantly falling to zero — some current manages to continue flowing by jumping across the air gap. Therefore, di/dt is not infinite (and negative), but it's still a large value. If you have a neon connected across the inductor terminals, current will preferentially flow through the ionised neon gas rather than jump through air. |
| Jan29-13, 06:14 AM | #6 |
Here's a question for 'the student' - What happens if there is no spark or 'neon'? (If the insulation is good enough and there clearly can't be infinite voltage.)
| Jan29-13, 09:20 AM | #7 |
Recognitions:
Well, this student says that if that's the case then you haven't rapidly interrupted the current, but rather gradually/steadily wound it back to zero.
| Jan29-13, 09:37 AM | #8 |
What was it that limited how fast you could 'wind it back'. "
| Jan29-13, 06:16 PM | #9 |
Recognitions:
The mechanical separation of its contacts was slow (and, indeed, smooth and gentle) enough that di/dt was limited during the separation process to a value that induced no voltage large enough to ionize any air across the separating points.
| Jan29-13, 06:26 PM | #10 |
No one likes a smartypants.
| Jan29-13, 06:32 PM | #11 |
Recognitions:
![]() P.S. I didn't say I believed the instructor's claim of the switch generating no spark.
| Jan29-13, 07:59 PM | #12 |
sophiecentaur
My confusion lies with the direction of current. 1. You said when the switch closes with position B, the voltage at the 'top' of the inductor is negative as shown. So shouldn't the direction of current be clockwise (from the diagram) because it has to go from the more positive terminal to the more negative right? 2. How is ground replaced? As I see it first the neon lamp was connected between point B and ground, but no circuit was being made (because switch was at A), after the switch closes with B the circuit is made, and ground stays where it was. The diagram sort of explains what is going in my mind. The arrow in the loop being the current direction |
| Jan29-13, 08:17 PM | #13 |
where I suspect sophicentaur is using electron current flow which is negative to positive so when its negative at the top of the inductor, current flow is anticlockwise from top of inductor down through neon through resistor and back to inductor hopefully I havent misread that ;) Dave |
| Jan29-13, 11:25 PM | #14 |
Recognitions:
Let's look at the elements apart from the inductor. How to get current to flow in a path that takes it DOWN through the resistor then UP through the neon? This can only happen if the top of the resistor is + with respect to the top of the neon. (Remember, current always flows from + to –.) BUT, we can see that the top of the resistor is the same point as the bottom of the coil, and the top of the neon is the same point as the top of the coil. So, if the coil is to maintain current unchanged when the switch moves to position B, we have shown that the bottom of the inductor must go + and its top must be – . And indeed it does! ![]() What we haven't examined is the magnitude of this flyback voltage. In this discussion all I've considered is its polarity. Remember: The voltage across an inductor can change instantly. It's the current through an inductor that takes time to change. |
| Jan30-13, 12:28 AM | #15 |
Have read a number of times and trying to make heads and tails of it ??
if so then after switching to 'B' its magnitude and direction ( for that brief time) is going to roughly be the same ? therefore you are not going to have current flowing through the neon as the voltage isnt high enough to strike/light the neon ? and its going to flow in the opposite direction ? its that spike thats going to be high enough to strike/light the neon ? just wanna clarify this for myself too :) Dave |
| Jan30-13, 12:29 AM | #16 |
Recognitions:
The voltage across an inductor is no indication of the direction or magnitude of current through that inductor. To determine the current through an inductor you need to know its history.
| Jan30-13, 12:30 AM | #17 |
not sure who or what particular comment thats aimed at ?? I agree, and we do know the history :) so not sure what point you are making ? Dave |
| New Reply |
| Tags |
| inductor, switch, voltage |
| Thread Tools | |
Similar Threads for: Basics question of Inductor to powering high voltage lamp
| Thread | Forum | Replies | ||
| Circuits Question -- Voltage and current in an inductor circuit | Introductory Physics Homework | 2 | ||
| Calculating when voltage across resistor = voltage across inductor in an RL circuit | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Regulating/capping voltage for a lamp | Electrical Engineering | 1 | ||
| Measure High Voltage using Coil Inductor | Electrical Engineering | 8 | ||
| Voltage Drop Across Indicator Lamp | Introductory Physics Homework | 1 | ||
