Why Does My Graphics Card Keep Crashing When Playing Games or Watching Videos?
  • Thread starter Thread starter leroyjenkens
    Graphics
The user experienced multiple issues with their computer, primarily related to the graphics card, which caused the screen to freeze and display various colors while playing League of Legends. Initially, using a fan helped mitigate overheating, but problems persisted, including a black screen and green visuals when watching YouTube videos. To troubleshoot, it is suggested to disable the dedicated graphics card and switch to onboard graphics if available. This involves physically removing the graphics card and connecting the monitor to the onboard output. The BIOS typically defaults to onboard graphics when no dedicated card is detected. Additionally, potential causes for the issues include outdated graphics drivers, loose connections, or a failing graphics card. Recommendations include updating drivers, cleaning the graphics card, and testing with a different card if available. If these steps do not resolve the issue, seeking professional assistance is advised.
leroyjenkens
I used to play League of Legends, but I stopped playing it because my screen would turn a bunch of different colors and freeze. I set up a fan to blow inside the computer, and that kept it from freezing for a while, because I guess it was overheating, but then it started freezing even though there was a fan on it. So now I don't play at all. But now the card is causing my screen to go black whenever I watch youtube videos. The screen goes black and then cuts back on and shows a green screen where the video is playing. It also will basically shut off my monitor.
Is there any way to just disable it and use the onboard graphics card (assuming there is one)? I don't care about having awesome graphics, I just want the thing to stay working when I try to watch youtube videos.
Thanks.
Computer science news on Phys.org
This is all just speculation at the moment, leroy.
What graphics card do you have?
What kind of computer?
Do you know the make/manufacturer of the motherboard?
What operating system?
Have you done any upgrades to the hardware recently?
Have you loaded any new software recently?
Have you loaded any new drivers for your system's hardware, like the graphics card, recently?
If you can provide some of this info, it will go a long way to troubleshooting your problem.
If its a dedicated card and not an onboard chip first thing i would do would be remove it from the slot and give the fan and heatsink a good clean (i had a similar issue with dust build up that caused system freezing) have you updated your drivers? Make sure the cards power supply cables haven't cone loose causing a short. Hope some of that helps if it doesn't then just pull the card and plug your monitor into the onboard vga the bios will automatically switch back to that
Alright let's do this. Leeeeeeeeeroooooooy Jeeeeeeeeeenkiiiiiiiiiiiiiiins!
Sorry, couldn't pass that up :)
First, to answer your question about the onboard card. Take a look at this picture
http://attachments.techguy.org/attachments/188229d1298768706/monitor-sockets.jpg
Where it says "Installed Card" there's two connectors, a blue one and a white one. Compare that to the back of your system and see if you have either one (blue or white or both) where it says "Onboard" If you do, then you have an onboard card.
In that case, do the following
  1. Turn off computer
  2. Unplug power cable from back of system
  3. Open up the side pannel on the computer
  4. remove the gfx card (unscrew the bracket, there's usually a small plastic piece that you have to move and release near the base of PCI slot)
  5. put the cover back on
  6. plug the power back in, connect the monitor to the onboard card
  7. turn the computer on and you should be good to go
Or just google "how to remove a video card" from another system and you can watch videos
In most computers, the BIOS is smart enough to realize that you don't have a gfx card installed and to default to the onboard card. If that is not the case, then you will need to plug the video card back in, connect the monitor to that and boot into the BIOS (normally accessed by pressing the F2 key or the delete key during startup) Then within the BIOS you have to find and change the option that says use onboard or PCI video card to Onboard.
Again, google it if you're not too sure and look up images.
With regards to the problem itself. One of three things is happening. Either your gfx drivers are too old or there's a connection problem (cables or gfx card inside the computer) or the card itself is failing. I would do the following in order.
Download and install the latest drivers for your video card from the card manufacturer's website. If you don't know what gfx card you have download and run this program, it will help you identify it.
http://www.techpowerup.com/gpuz/
If that doesn't fix it, then time to clean
Get a can of compressed air. Remove the video card from the computer using the steps above. Use the can of compressed air to blow clean the fan and heat sink on the video card. Once it's as clean as you can get it, then plug it back in, connect the cables and try again.
If that solves your problem, great, it was a heat issue.
If that doesn't solve your problem, then we're most likely looking at a busted video card. The only real way to test is to swap it out for a known good card or using the onboard card (if you have one)
If neither is an option, then you're better off taking the computer down to a computer store and asking for help testing.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
