Hermitian operator-prove product of operators is Hermitian if they commute
In summary, if A and B are Hermitian operators, their product AB is Hermitian if and only if A and B commute. This can be proven by using the definition of Hermitian operators (A = A*) and the fact that the product of two Hermitian operators is Hermitian if and only if the operators commute. This relationship can also be understood by considering the eigenfunctions of Hermitian operators, which show that commuting Hermitian operators have simultaneous eigenfunctions.
Dunhausen
30
Hermitian operator--prove product of operators is Hermitian if they commute
If A and B are Hermitian operators, prove that their product AB is Hermitian if and only if A and B commute.
1. A is Hermitian if, for any well-behaved functions f and g,
[tex]\int f^* \hat{A}g d\tau = \int g (\hat{A}f)^* d\tau[/tex]
2. If A and B are Hermitian, then (A + B) is Hermitian
3. The Eigenenfunctions of a Hermitian operator that correpsond to different eigenvalues are orthogonal.
4. Commuting Hermitian operators have simultaneous eigenfunctions.
5. The set of eigenfunctions of any Hermitian operator form a complete set.
Well, it seems I could play around with this
[tex]\int f^* \hat{A}\hat{B}g d\tau = \int g (\hat{B}\hat{A}f)^* d\tau[/tex]
[tex]\int f^* \hat{B}\hat{A}g d\tau = \int g (\hat{A}\hat{B}f)^* d\tau[/tex]
and try and set the different halves equal, or something, but I can't seem to justify moving any terms around.
Property #4 has the appearance of relevance; however, I also do not think I can arbitrarily turn the operators into functions and still go forward with the proof.
Besides the above points and a little discussion of how operators distribute/commute, there doesn't seem to be much basis from my course knowledge to figure this out. But hopefully I am missing something simple?
Welcome to Physics Forums Dunhausen!
You're not turning an operator into a function. Property #4 means that if [A,B]=0 then [itex]A\psi[/itex] and [itex]B\psi[/itex] can be known simultaneously where [itex]\psi[/itex] is the eigenfunction. The most likely won't have the same eigenvalue, but the eigenfunction will be the same for the two.
Hope that helps a little.
Don't overthink the problem, just try writing down the few relevant facts.
First write down the condition (definition) for the product AB to be Hermitian. I can save writing integrals, etc. by just writing down the operators.
AB = (AB)+
Now expand the right hand side, and apply what you know (that A and B are individually Hermitian). You should see the solution from there. Write again if you need more help.
jdwood:
Well, I'm happy to have a better understanding of the property! I guess I had just been wondering whether thinking in terms of eigenfunctions instead could verify the intended theorem.
marcusl:
The only definition I had been given for the Hermitian operator was the form of the integral.
The expression "AB = (AB)+" is somewhat mysterious to me. Are you use + the way I am using *?
As far as I can tell, he is. Most physicists use a dagger (which is sort of like a +) to mean the hermitian conjugate.
Figure out how to write (AB)* in terms of A* and B* using the definition of hermitian. The rest should fall out naturally.
Ah! You will have to excuse me, as noted I was not familiar with the notation (and had only seen the integral form!) but from what you just said, I assume that all of these properties apply:
(A+B)*=A*+B*
(rA)*=rA*
(AB)*= B*A*
A**=A
And "Hermitian or self-adjoint if A = A*" is what marcus meant when he said the definition of the Hermitian is AB=(AB)*.
So I can say:
assume A, B, and AB are Hermitian.
AB=(AB)*=B*A*=BA*=BA
therefore, AB commutes.
Fyi, neither my professor nor my text discussed matrices, but this makes more sense to me than thinking about it in terms of integrals. However, I would love if anyone can think of any introductory references about the matrix method, especially which might help me to see why the formulations are equivalent.
What text are you using?
J. J. Sakurai, Modern Quantum Mechanics (first chapter)
Atkins and De Paula, Physical Chemistry, 8th edition.
Also, thank you. Gokul!
Sorry I couldn't get back to you in a timely fashion, Dunhausen--a family medical emergency required my attention. I indeed used + to mean Hermitian adjoint, and you figured it all out nicely. Good work!
What is a Hermitian operator?
A Hermitian operator is a type of linear operator in quantum mechanics that represents an observable physical quantity. It satisfies the condition that the operator is equal to its own adjoint, or complex conjugate transpose.
What does it mean for operators to commute?
Operators commute if they can be applied in any order without changing the result. In other words, the order in which the operators are applied does not matter.
Why is it important to prove that the product of operators is Hermitian?
It is important to prove that the product of operators is Hermitian because it ensures that the result is a valid observable physical quantity. Hermitian operators have real eigenvalues, which correspond to the possible outcomes of measurements in quantum mechanics.
What is the commutator of two operators?
The commutator of two operators is a mathematical operation that determines how much the operators do not commute. It is defined as the difference between the product of the two operators and the product of the same two operators in reverse order.
How is the commutator related to the product of operators being Hermitian?
If the commutator of two operators is equal to zero, then the operators commute and the product of the operators is Hermitian. This is because a zero commutator indicates that the operators can be applied in any order without changing the result, which is a characteristic of Hermitian operators.
