DarkMatterHol
- 35
- 1
Hi. Just watched a Nova special with Brian Greene, "The Fabric of the Universe/The Illusion of time", describing significant time dilation when two frames are moving towards or away from each other at low velocities, when the two frames are separated by great distance.
This left me with a couple of questions. The first would be, doesn't this mean, in an expanding universe, that we see the rest of the universe as it was, very much earlier than we otherwise would by taking only the speed of light into account?
Since time began with the big bang, and distant parts of the universe are dilated to earlier times, does this not mean that from any frame, most of the observable universe gets scrunched into the moments after the big bang? I mean there will be a huge dilation shift for events soon after the big bang, because these events are both so far away and moving away so fast at the same time, that those events would be shifted in time to before the big bang itself, unless those events were squished against the big bang boundary, or... this is what i would like to understand.
The other question that came up is the following - Let's say we have two distant galaxies, and we, in our galaxy have a telescope with which to observe a solar system within the distant galaxy. If we observe the distant solar system while traveling at say arbitrarily at 20MPH towards that galaxy, the 'now' time for that galaxy will be shifted toward the future in out frame. Conversely, if we travel away from that galaxy at 20MPH the 'now' time for that galaxy will be shifted toward the past in out frame. for very distant frames the shift is hundreds or thousands of years. My question is, does this mean that if we were to travel in a circle, as we ride the Earth around the sun, moving towards and then away from the solar system in the distant galaxy, would we not see the planets in that solar system running forward and then backwards, once every year? Would we not see time in that distant solar system oscillate forward and then backward, as a sine wave? The planets processing forward, then backward each Earth year?
To my understanding, the only requirements for this to be true, the orbits of the planets would need to be on the order of years, while the distance between galaxies would have to be sufficient to dilate relative time by a factor of several years. The procession of local times would distort the sine wave function of relative time slightly as local times move along.
Looking forward to your thoughts, explanations.
Regards,
Regards,
